-   -   Kraftwerks Supercharger Owners Thread (https://www.ft86club.com/forums/showthread.php?t=48406)
TmP 06-09-2014 09:51 AM
Originally Posted by post_break (Post 1786278)
I did 94ft lbs and the pulley bolt fell out later that day. I went to 120 after that. And rechecked it a dozen times.
Say what????
post_break 06-09-2014 09:52 AM
Originally Posted by TmP (Post 1786282)
Say what????
Yes. The bolt came out. My pulleys were hanging on by a thread. Check your torque, don't just torque and assume it's good. Check it warm and cold.
J_kennington 06-09-2014 10:06 AM
Very possible that it fell out. You don't measure a "90* turn" with torque. You measure it with an angle torque wrench.
zoth 06-09-2014 11:03 AM
Sh!t, going to check mine right now. :sigh:
King Tut 06-09-2014 12:09 PM
Originally Posted by post_break (Post 1784489)
That's like negative 10-15.
Originally Posted by zoth (Post 1784526)
Mine never goes less than -10
I hope you guys aren't talking inHg because you both definitely have a vacuum leak if you are. These motors should be pulling -19 to -20 inHg at idle and can go higher when off throttle in high vacuum situations. Remember not every boost/vacuum gauges reads in inHG and PSI though.
post_break 06-09-2014 12:17 PM
This is what mine says at idle.
zoth 06-09-2014 12:43 PM
Mine always reads like that even before SC. Picture is with E85 flex tune.
captain_jack 06-09-2014 12:43 PM
Hey how do you like that gauge pod,I have it and haven't bought the failsafe yet.
may the schwartz be with you....
glamcem 06-09-2014 01:14 PM
Originally Posted by FR-S Matt (Post 1786214)
Are you guys running 0w-20 after supercharging for your daily drive? Not looking to get into an oil debate, but just wondering if that weight will suffice for DD and a little spirited driving or should I bump up to a bit heavier weight? I've got an oil change up coming up soon.
user manual states that the 5w-30 can bu also used and that's what many people with FI use on their cars..being in Texas, I would never consider 0w-20
I am not sure how is that even possible, I've attended 2 track events after the KW kit and after many many pulls I didn't run into any issues.. I will check by torque again to make sure..
btw, why did you torque it to 120 ft/lbs? Is that just a random number?
MAPerformance 06-09-2014 01:53 PM
Looks like you might have A/F reading in the LCD screen, and your boost/vacuum in the LED portion.
post_break 06-09-2014 01:59 PM
I read somewhere in this thread others were torquing to 120. After torquing to that it hasn't budged. I even tried to remove the bolt to replace it with a brand new one and couldn't get it to budge. So said screw it, she's staying in.
AFR is on the LCD, vacuum on the LED yes.
King Tut 06-09-2014 02:35 PM
(-10) pounds per square inch = -20.3625437 inHG
We have to make sure everyone is talking in the same units. It appears that both of you guys are pulling the correct amount of vacuum at idle. :thumbup:
zoth 06-09-2014 02:40 PM
We'll that's good to know, thanks.
Sent from my SM-N900T using Tapatalk
NCItaly 06-09-2014 02:54 PM
Are you getting afr off the obd2?
