I was reading on the vortech website that anything above 10psi you will need to change the bypass valve?
How big is the crank pulley on the BRZ?
I'd have to measure one - which I have somewhere in my garage - but the OEM part number is 12305AA370 so you might be able to google it.
Thanks - Google says 5.826748713587742 - that may not be exact but it's close.
Do any of you have a part number for the belt required to run the 2.87 pulley? I plan on running it soon with 93/E85 Currently making 363HP on E85
Currently running a 3.125 pulley on 93, maybe making somewhere in the upper 200's, never dynoed. Wanted the smaller pully mostly for a little earlier boost rampup, tuner pulled a bit of timing on the top end.
Related question: stock clutch is holding fine on the power it is making now, if I decide to go flex fuel and run E85, think a new clutch is necessary? I don't typically drive like a lunatic, no heavy slippage/launches, mostly just rolling in-gear stuff. Sent from my SM-G965U using Tapatalk |
| All times are GMT -4. The time now is 09:05 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
