-   BRZ First-Gen (2012+) -- General Topics (https://www.ft86club.com/forums/forumdisplay.php?f=23)
-   -   BRZ Ts parts (https://www.ft86club.com/forums/showthread.php?t=45255)
mister.bond 05-05-2014 05:14 AM
Hm, ok, 1.3 insted of 1.1
If there is really a difference to the radiator Caps in holding more pressure
then..... it would be interesting how much difference the Caps have
in their weight !
It would be nice if someone can do that and give us the
weight from the original Radiator Cap and the STI Radiator Cap.
Letīs see if the STI Cap is " Stronger" Build and is minimal heavier
from material cause of the "higher" 1.3 pressure-proof :happyanim:
Khazzy 05-05-2014 07:52 AM
in their weight !
I will do a weight comparison when I receive it and I return next month.
Createddeleted 05-05-2014 03:22 PM
If you don't get to I will.
But really. It's the nearly the same cap, from the same manufacturer; it just has a different sticker and a stronger spring.
krayzie 05-05-2014 06:07 PM
It's probably the same build but one is tested to make 1.3 bar while the other could only sustain 1.1 bar.
It's probably like G-Shocks where they all do 200m water resistance supposedly, but only the Frogman has every unit tested to ISO standard of 200m before they roll off the assembly line. Another watch example is the different grades ETA has for a single movement model, same build but different quality of components and finish / assembly that can affect the accuracy when tested (i.e. chronometer > top > elabore > standard).
Trap63 05-06-2014 02:46 PM
here part code.....
Attachment 77605
Inviato dal mio iPhone utilizzando Tapatalk
Khazzy 05-07-2014 11:20 PM
I asked Yuki if they can carry the steering wheel trim from the tS but that seems like a dead end to me. Maybe a frequent contact with Yuki can get him to push for the part to be added.
BRZtoni 05-08-2014 12:27 PM
test fitting my STI side skirts.
will be getting the set painted once rear spats arrive
http://i925.photobucket.com/albums/a...Z/IMG_8464.jpg
Turbo95eg6 05-08-2014 02:42 PM
lol poor dog
BRZtoni 05-08-2014 03:06 PM
Originally Posted by Turbo95eg6 (Post 1723863)
lol poor dog
when I make my car journal, you will get to know him more.
he has an eye infection so I need to put on the cone so he could stop
scratching it more.
Beyer Subaru 05-08-2014 06:32 PM
Whaddya talkin about @Turbo95eg6 ? That dog now has the best hearing on the block.
psyclone07 05-08-2014 07:01 PM
Anyone actually receive a STI/TS kit from the dealer with the US part numbers?
BRZtoni 05-08-2014 09:15 PM
I checked with my buddy who works at Subaru.. and none.. I ordered my
set via nigeljdmparts
mister.bond 05-09-2014 04:32 AM
Strut and Coil Spring SET
New Part arrived at Japanparts :D
http://www.fotos-hochladen.net/uploa...6ls8wi1eoc.jpg
look here :
http://www.japanparts.com/db/parts_d...&SEARCH_page=2
i wonder if it is only for Front ;
Does anybody can tell me if it is possible to also take one Set for REAR ?????
The359 05-09-2014 05:04 AM
You have to order the fronts and rears separate.
http://www.japanparts.com/db/partsli...KEY=484-036-02
