I almost pull the trigger to buy the Bilstein B8. (I have already bought the standard pink STI spring, but have not yet install.) I change my mind after I carefully reading the STI website again. (I put it in Google translate) http://www.sti.jp/parts/catalogue/br...0330AS000.html It sounds like standard pink STI spring is designed for the Stock shock. Bilstein B8 (or STI tuned Bilstein) might match with new pink STI spring (front is different than standard one) and 18 inch wheel better. Thanks. |
I read the announcement as below http://car.watch.impress.co.jp/docs/...10_643687.html It looks like this new shock is for 18 inch wheel, so need to rebalance the handling and comfortable. I am not sure the different between the 2015 GT86(FRS) and 2015 BRZ, but the spring is the only suspension different between 2013-14 FRS and BRZ. I am a BRZ owner, so I prefer to keep this small unique points and try to believe that Subaru (STI) can tune this car better than Toyota. So, I will temporary go STI standard pink spring on stock shock with 17 inch wheel and wait and see how Subaru modify this parts on 2015 BRZ. However, I might consider (or copy) BRZ STI (ts) setup (Bilstein+ new STI front spring) or Toyota (Sachs), if I upgrade to 18 inch wheel. Thanks. |
If you look at the STI Peformance Catalog, they will specify if the part is compatible with Rev. A (MY2013) or Rev. B (MY2014). If they are using stiffer bolts for the engine crossmember and rear shocks, I can't wait to see if they will rate the handling and chassis parts to be compatible with Rev. C (MY2015). |
Actually, I am trying to say standard pink STI spring match stock shock better than Bilstein B8. So, I change my mind and will not buy the Bilstein B8. Sorry for the misleading. Thanks. |
[QUOTE=chanomatik;1683819]Almost Stalker Status...
NO ! not at all,..... bitte erst nachdenken, dann schreiben ! the thing is, if someone do NOT reply to PNīs 2 times..... i thought the PN writing does not come through....... so, that is the reason why i try to write here to the person.... but now, i know.... er hat einfach keine Bock zu antworten ! |
okay, guys!
need price for this airbag cover with STI logo |
airbag STI Logo Badge is not available....
but ...... i wrote to japanparts cause of the STI Air Filter ( PART Nr. : ST16546ZA000 ) and..... then 10 hours later....... they listed the STI Air Filter :party0030: Link : http://www.japanparts.com/db/parts_d...=&SEARCH_page= ok, without a photo, but its ready for Order :happyanim: |
[ame="https://www.youtube.com/watch?v=GTKAJUkEwuo"]Relax man, it's just... - YouTube[/ame]
tS radio shroud and dash piece for RHD is now available too under Subaru Parts on japanparts.com
Yes i do ask him about the radiator Cap.
but i think i wrote to late cause no answer yet. when i wake up here in Germany i have only a short time to contact the Guy from Japanparts cause of the Difference in Time between Germany ( Me ) and Japan ( Guy from Japanparts ) :-)))) So , when i start the day, he leave the office a few minutes later :iono: but i think he will answer tomorrow ps : searching for used STI Axelback / |
| All times are GMT -4. The time now is 06:42 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
