-   -   Pic Request: 17x9 on stock suspension (https://www.ft86club.com/forums/showthread.php?t=42746)
knipple 08-15-2013 05:56 PM
I am running -1.0 degrees of camber in the front with Enkei RPF-1 17X9 et +35 using BFGoodrich Gforce Rival tires 255/40/17. I have almost no clearance between the tires and the spring perches in the front. I currently have no rubbing.
2pt5RS 02-25-2014 02:18 PM
I was so set on getting a set of 17x9 RPF1s on stock suspension until I saw this thread.
jonbonazza 02-25-2014 02:47 PM
OT: Will 17x9+45 clear factory shocks with RCE springs as well as stock suspension?
wparsons 02-25-2014 02:50 PM
Just get +35 instead of +45 and you'll be fine.
2pt5RS 02-25-2014 02:58 PM
I'm not as concerned about the rubbing as I am the rally look. I want it to look better than that.
Maybe I'm oblivious, but is that how stock looks?!
hmong337 02-25-2014 03:57 PM
The stock height is hideous. I actually just got my set of wheels. Went with 18x9 +38 around and will not be mounting them until I lower the car with either springs or coilovers.
2pt5RS 02-25-2014 04:14 PM
yeah...my problem is that I already scrape all over atlanta. lowering the car would make me scrape MORE. Although, I guess I could take the HT Autos front lip off. :\
IAmNotTheDriftKing 02-27-2014 05:32 PM
Anyone running a 17x9 with a 40mm or greater offset with about -1.5 degrees of camber?
leicaboss 02-27-2014 05:49 PM
I hear your pain my friend. Personally, mine has a rally-inspired look. The Rally Armor mudflaps help give it that nature too! Especially with Black RPF1's :w00t:
vroom4 02-27-2014 06:34 PM
Yes, look at MachV's comments in this thread. He has both sides of the -1.5
-1 with oem crash bolts and -2 with top hats. Both work with his +42 wheels.
IAmNotTheDriftKing 02-27-2014 07:08 PM
I read about the top hats but I didn't see anything with the crash bolts. -1 degree would be fine I guess, I don't want to spend to more than 1000 dollars on wheels(excluding tires) and suspension, so top hats are a no go.
Anybody else running camber on a 42mm offset?
Fez96 02-23-2017 03:24 PM
Originally Posted by Lee358 (Post 1117230)
17x9 +45 rpf1 with 245/40/17
Attachment 46737Attachment 46738Attachment 46739Attachment 46740
The last picture is the distance between the tire and the coil i have had no rubbing in the last month since install. Wait thats a lie i rubbed once pulling into my very steep driveway thats about it.
Are you on stock suspension because I'm on TRD springs and my Rpf1 won't even go on the car because it just hits the spring in the front
