-   -   Pic Request: 17x9 on stock suspension (https://www.ft86club.com/forums/showthread.php?t=42746)
fstlane 08-06-2013 08:58 AM
Originally Posted by garfull (Post 1121194)
are you maxed out negative on the camber bolts?
No, this is running the factory bolts and alignment. I had hoped to add some negative camber with crash bolts but it looks a little tight.
raul 08-06-2013 09:19 AM
Originally Posted by fstlane (Post 1118395)
I'm curious also. I'm running 17x9+42 Rota Titans with 245 Direzza Z2 tires and I have about 4mm of clearance. This is with stock struts, camber bolts and alignment. The only thing I replaced was the springs with RCE Yellows.
Do you happen to know your alignment specs in the front? Looks like there's very little space to dial more negative camber in.
hmong337 08-06-2013 12:53 PM
Originally Posted by Mach V Dan (Post 1119054)
Yes, these pictures are of stock suspension. That was the original subject...
--Dan
Mach V
Will your wheels rub with 2 degrees of negative camber? ...let's say with a 255/40/17 tire.
I'm essentially looking for something that will not rub at full lock, yet having the ability to clear everything even with mild drop springs later down the road when I decide to lower the car and add camber bolts.
fstlane 08-06-2013 02:21 PM
No, I'm sorry I haven't had it aligned yet as I'm waiting on camber plates to arrive. I'm guessing it's pretty close to zero or whatever the factory specs is though. I doubt you could dial in any significant camber with bolts unless you used a 3mm wheel spacer to add a little more perch clearance.
Mach V Dan 08-06-2013 02:27 PM
Originally Posted by whataboutbob (Post 1118303)
Are you are on stock suspension/ride height? If so, ok. I couldn't get a 255 on a 17x9et35 on my car with the RCE springs/factory struts, Whiteline camber bolts, and COMCs.
With camber from the Com-C top hats, no. I have that now.
http://i6.photobucket.com/albums/y24...e.jpg~original
--Dan
Mach V
hmong337 08-06-2013 10:50 PM
--Dan
Mach V
Love the license plate! Lol
How many degrees are you running with the top hats?
Mach V Dan 08-07-2013 10:36 AM
About 2 degrees.
--Dan
Mach V
peachch 08-12-2013 01:15 AM
http://i1299.photobucket.com/albums/...ps1c6b50e0.jpg
http://i1299.photobucket.com/albums/...ps72ec0857.jpg
How much camber are you running?
I am running -1.2deg with 18x8" ET 49 , 235/40R18. I am planning to switch to 17"x9" et 40, but clearance is too narrow now.
fstlane 08-12-2013 10:31 PM
I am running -1.2deg with 18x8" ET 49 , 235/40R18. I am planning to switch to 17"x9" et 40, but clearance is too narrow teenow.
I'm sorry I haven't had it aligned yet as I'm waiting on camber plates to arrive. I'm guessing it's pretty close to zero or whatever the factory specs is. Your et40 offset is about an ideal compromise between tire poke and strut clearance with a 9" wheel. Which wheel were you considering?
NoppyNop 08-12-2013 11:02 PM
Here is mine with 17x9 +45 offset with 225/45/17 tires.
http://i25.photobucket.com/albums/c9...83218EEB77.jpg
peachch 08-13-2013 02:13 AM
I am thinking of TE37
fstlane 08-13-2013 09:00 AM
Those are really nice wheels!
svodka 08-14-2013 03:27 PM
Very nice, any rubbing at all? Been looking at 17x9 +45s but hearing that it rubs at full lock on stock suspension..
NoppyNop 08-15-2013 05:44 PM
So far no rubbing, I took it to the track last weekend and no problems.
