-   -   Pic Request: 17x9 on stock suspension (https://www.ft86club.com/forums/showthread.php?t=42746)
Lee358 08-04-2013 01:40 PM
Originally Posted by hmong337 (Post 1117389)
@Lee358
Wow! That's cutting it close. Is there any rub on full lock?
Thanks for posting.
not that i have experienced
garfull 08-04-2013 02:52 PM
Mines rubbed the front shocks on 17x9 45et with 245/40/17 ego v12 tires on OEM suspension in hard cornering.
Lee358 08-04-2013 02:55 PM
did you end up with a spacer?
garfull 08-04-2013 03:03 PM
Long story short I went coilovers but now I'm switching back to OEM shocks. There was 2mm of clearance when it rubbed. Going to look at 5mm spacers on the front but I'm still concerns that with the camber bolts I'm still going to rub. Will have to see once I swap the suspension back.
garfull 08-04-2013 03:14 PM
hmong337 08-04-2013 03:45 PM
Yea, this is the reason I was looking into the offset ranges as I don't want any clearance issues with anything +40 or higher.
wparsons 08-04-2013 04:06 PM
If you want to run useful camber up front from camber bolts (-1 to -2*) you'll want +35 with 17x9 wheels. The +45 might fit at 0* but it might rub and will definitely rub if you run camber bolts.
whataboutbob 08-04-2013 11:26 PM
Originally Posted by Kai Uhl (Post 1117030)
how would one get those whiteline decals?
I had them custom made by a local shop. I won the AutoX raffle at the last 86fest and got a amateur sponsorship out of it. PM me and I can get you in contact with the shop that I worked with if you are interested.
whataboutbob 08-04-2013 11:27 PM
Are you are on stock suspension/ride height? If so, ok. I couldn't get a 255 on a 17x9et35 on my car with the RCE springs/factory struts, Whiteline camber bolts, and COMCs.
fstlane 08-05-2013 12:11 AM
I'm curious also. I'm running 17x9+42 Rota Titans with 245 Direzza Z2 tires and I have about 4mm of clearance. This is with stock struts, camber bolts and alignment. The only thing I replaced was the springs with RCE Yellows.
http://i1299.photobucket.com/albums/...ps1c6b50e0.jpg
http://i1299.photobucket.com/albums/...ps72ec0857.jpg
Mach V Dan 08-05-2013 10:47 AM
Yes, these pictures are of stock suspension. That was the original subject...
i'd like to get a taste of how a 17x9 setup will look on the stock suspension.
--Dan
Mach V
karma003 08-06-2013 12:25 AM
Originally Posted by siXXtoes (Post 1116055)
17x9 +35 with 225/45/17 MPSS on stock suspension
What wheels r those?
garfull 08-06-2013 01:05 AM
are you maxed out negative on the camber bolts?
siXXtoes 08-06-2013 03:08 AM
rays gram lights 57dr's in gun metal blue
