sent from a Galaxy SIII... |
so drl resistor unplug, plug left on the car that normally goes into the drl resistor, tap into those prongs in the connector and it should be good? |
any way to get pics of the drl wiring portion? i'm confused as to what's going on here.
http://i1327.photobucket.com/albums/...ps22d41d20.jpg |
Thanks for the DIY! Got to install mine today and this made it so much easier.
http://i1177.photobucket.com/albums/...psa3efd554.jpg http://i1177.photobucket.com/albums/...pscf33fa91.jpg |
FYI, if you want a reversible install for the last pin (DRL), find some single pin connectors online. I had a set left over from a motorcycle HID kit I never used and it made everything look even cleaner. Just a suggestion to avoid having to remove the pin from the last wire. :)
only thing I will mention is that if you have a vortech kit and a perrin oil cooler. the driver side is going to be a pain in the ass with the reservoir that comes with the vortech kit. all i'm saying is it's gonna be squished a bit haha. also the oil lines need to be moved over towards the center to make everything work. the passenger side is gravy! |
| All times are GMT -4. The time now is 07:02 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
