-   DIY (Do-It-Yourself) Guides (https://www.ft86club.com/forums/forumdisplay.php?f=43)
-   -   DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) (https://www.ft86club.com/forums/showthread.php?t=39313)
Chaetagnath 05-09-2016 08:10 PM
Originally Posted by nunonuna (Post 2597224)
I don't know if it will help you or not, but after I swapped my battery for new one, it never happened once for 3 months so far. It seems like it happens if the battery charge is lower, at least in my case. I was lucky that I was covered by warranty from Braille. Since my battery is lightweight AGM from Braille, I cannot say it is the case for everyone, but it worked for me. ;)
Got a new battery, fixed the problem.
kennyd8606 08-08-2016 12:58 PM
hi can u show me where can I buy that keyhole slot cover at I got a push to start install in mine but can't find that cover for the key hole anywhere
XtremeMaC 08-08-2016 01:02 PM
Hello P/N is 34348CA000VH
I've purchased mine from Hodges Subaru
kennyd8606 08-08-2016 07:48 PM
thank alot for the reply!!
Lorico 11-09-2016 02:12 PM
doesnt seem like amazon carries this any more :(
XtremeMaC 11-09-2016 04:33 PM
Amazon still carries it. Here is the link
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
dejahboi 11-22-2016 01:54 AM
http://i737.photobucket.com/albums/x...ps2a7b626b.jpg
Remove the piece in the back with long nose needle nose pliers, and there is more room to get at the steering wheel lock.
http://i737.photobucket.com/albums/x...psdbc9fbe5.jpg
Once that’s out you can reinsert the ignition cylinder if you like (or leave it out).
I did the third method, and removing that little peg will engage the steering lock which defeats the purpose of disabling the lock itself.
I had to learn it the hard way and find a way to reinsert the little peg back into the cylinder. Instead what I end up doing is leaving that back piece and rotating it to the right locking the peg in place. I did everything else (remove the harness from the ignition) and its working fine. I also did everything on the steering column without removing the ignition assembly.
meekrob 12-21-2016 07:53 PM
wow awesome write up, helped a lot, thanks!!
blindsta 04-30-2017 03:29 PM
Hi I want to buy the EasyGo system for my corolla 2009, and I want to know if it has given you problem or the product is recommended?
nunonuna 05-02-2017 12:28 PM
Shoot!!! Price of this kit is reduced significantly lol. Amazon sells it for $150 now. LOL
blindsta 05-03-2017 09:30 AM
Can someone tell me if the system is recommended or gives many problems please
nunonuna 05-03-2017 10:53 AM
Assuming you read this thread completely, there is only one minor issue related to remote start. If there was more problem, few of us would already posted something in this thread. So I would say no headache at all~
blindsta 05-03-2017 11:43 AM
Thanks for your reply, i will buy it and let know here the result of whether it worked or not
XtremeMaC 05-03-2017 12:04 PM
wtf? firestorm color $187. rest shows $632. I'd buy the firestorm and get it painted instead, or not even use the door handle :)
