Still a bad habit I do.. |
Can't ever let go in the s2k though... bad idea there. [ame="http://www.youtube.com/watch?feature=player_embedded&v=-5yNHPaIvuU"]Look Ma! No Hands - YouTube[/ame] This is magic. This does not happen IRL. |
Would 255/40-18s (vs 225-235) be noticeably too much tire for a naturally aspirated car? I'm just getting back into tracking but I'd still like to be reasonably competitive.
How can I avoid the inevitable DI seal failure?
Competitiveness really depends on who your local competition is. |
Okay, seriously, don't redline. If you do, roll onto the throttle slowly after you shift. |
If we can confirm that this is definitely the root cause of these engine failures, and Toyota/Subaru is unwilling to band-aid it with an ECU update, then there's really no point in keeping the car. :( |
Wonder if the 91 octane gas (highest available in Cali) has anything to do with it. Maybe it's causing more detonation compared to 93? |
Good thing seems like it's a relatively new problem that hopefully is under investigation. |
How's fuel starvation?
Can't say the same for those running E85 and/or aftermarket tunes and fuel pumps. Definitely a no-no with FI. |
Both ways you have to think if your car will have long term effects from damage that possibly have already occurred Thanks Obama |
I know you're a Honda guy but do you know roughly how fast the wheel bearings and other parts would go out if you're on low offset wheels? Not really sure but I would think tracking a car would see higher stress compared to normal street driving.
Ideally I want around 40 offset wheels but it seems the more popular wheels only come in mid 30s |
My cars been on 98 and e85 it's lifetime, tracked & drifted and up to 17 psi on stock internals, and a bit of a delay in getting the injector fix flashed. Seals are fine still! Just a ray of hope in all the doom and gloom.
Setup question! Dialling out low speed rear wheel skip/lift? |
This. I'm about to pull my rear bar this weekend and see what it does. I also am increasing front swaybar size, and softening the rear damping. I'm having the same problem. |
Mike - stock tires nearing the end - if i want to go RS-3 what tire width would you recommend for stock wheels? 225?
Mike, I don't have a question.
I just thought I'd share this baby with you.. $28k, 733rwhp http://seattle.craigslist.org/see/cto/3966920765.html (car is in Utah) Few cars in my life have I wanted so bad. |
^ Why would anyone want a beat up racecar?
... because racecar! |
This thread reminds me so much of the tirerack random tire question commercial :thumbup:
I've got a question about gear shifting and letting out the clutch. One the street I drive pretty smooth (I think I may be over cautious) and release the clutch slow enough to minimize the driventrain lash/thunk/stress from quickly letting out the clutch.
In terms of performance driving, how much stress/thunk/lash can you put on the clutch/engine mounts etc...as you shift gears without long term damage? I don't ever drop launch the car from a stop but I'd like to know how far I can push the drivetrain with quick shifts from say 1st to 2nd, or quick downshifts from 4th, to 3rd or 2nd. |
That being said, as long as you're not SLAMMING gears, you should be okay. The stock clutch doesn't grab hard enough to REALLY shock the gears; you'll notice a screeching noise if you do really really hard shifts. This is the clutch slightly slipping on that fast shift, which is absorbing some of the shock load. |
I'd go slow on the shifts just to avoid DI seals failing :D
[ame="http://www.youtube.com/watch?v=vOeGz2W63OM"]Scion FR-S Chasing Porsche 997 GT3 @ Circuit Of The Americas (Track) - YouTube[/ame] |
So...I bought a spare pair of stock rims and wrapped them with used 225/45 from a tire shop. Planning to use these on the track (rear tires), in the 86 Dynamic Driving Academy to be precise, which focuses on the drifting aspect.
Am I doing it right? |
Bump
I'd recommend taking all of them! The car will easily fit 4 rims and tires in the back seats. But you bought a pair... Do you have a reason for wanting more rear grip on track? You're gonna understeer.... |
| All times are GMT -4. The time now is 07:31 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
