http://i60.tinypic.com/23kvfns.jpg
I don't know why my picture turned sideways, but besides the rear camber, does my alignment look ok for track setup? I already purchased whiteline rear LCA to fix my huge negative camber in rear |
IMO not enough front camber. You'll wear the outside shoulders of the tire pretty heavily. Toe is pretty much what I'd aim for (maybe a bit less rear toe? not sure how sensitive the BRZ is to that)
I'll let someone with more track experience with this platform give you better numbers, but check the alignment threads on the forums. |
Do you have camber plates? What kind of tires and suspension do you have? It seems you're slammed if you're at -3.3 without arms. |
I have the hankook evo2s 255/18. Kwv3 coilovers, ptuning front+rear sways and whiteline endlinks. About to install whiteline lca. I'm not slammed but I did get rid of wheel gap. |
But I've tracked like this before and it wasn't so bad. Actually it still performed well. But I think the camber is too much. I like the toe. So what camber front/rear would you suggest? I was thinking -2f/-2.5r |
This is a thread for performance driving applications, and I'm telling you that you're too low for a performance application of the KW V3. You're gonna run out of stroke length, and that'll cause your rear end to respond erratically. Do you want to look pretty or go fast? You could, theoretically, do both, but not with a KW V3. |
all this talk about camber is making me want to get camber plates on my fronts.. Tired of having 1.5 lol
how low are you exactly?
I don't feel like I'm too low. I don't find it difficult driving on normal streets. I am still like 3 inches off the ground on front and like 5 inches in rear from the rear diffuser. However, I am on max low on front as KW will take me(I know this is bad for handling) but in the rear my coils have plenty more to drop.
@bjun, please don't take this personally, but have you read the following thread?
http://www.ft86club.com/forums/showthread.php?t=67345 |
| All times are GMT -4. The time now is 07:31 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
