The unintentional rotation was less severe than the slippery tires that caused me to drift not track. I already knew how to recover from a skid (all snow country drivers do or don't survive) and drifting doesn't interest me, it wears out tires quickly and is a slow inefficient way around a track. http://i628.photobucket.com/albums/u...ps3eb3bee8.gif CERBERUS |
Kind of random question. I am about to register for NASA HPDE @ VIR July 19 20
If I want to bring someone that wont be driving or riding along do I need a family/spouse membership? Or is a basic 1 year membership satisfactory? |
Slippery tires interfered with that objective when I was a beginner. With my sticky tires when I approached the limit all 4 tires squeeled. What happened ? The sound notified me of the limit, then I either slowed to regain more traction or pushed harder to learn that speed was scrubbed off. There was no spin out off the track like with slippery tires. As in my original post - FOR ME I learned faster with sticky tires. http://i628.photobucket.com/albums/u...ps3eb3bee8.gif CERBERUS |
Only drivers need memberships to get on the track. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
Im tracking the Mosport Gran Prix track next week (long high speed straights and corners). Any tips on how to better throttle steer ? http://i628.photobucket.com/albums/u...ps3eb3bee8.gif CERBERUS |
It's an amazing experience. Ask your instructor everything that comes to mind, even if it is mundane or seems silly. Having an experienced driver in the car as a resource is the most valuable thing NASA HPDE offers. |
What Mike is specifically referring to is when you're at the limit of adhesion and the tires are considering stepping out on you. If you jump on the throttle, you break traction and go for a spin. If you let off the throttle, you regain traction but the car loses speed. If you're very delicate and smooth with the throttle, you can edge just past the limit and barely start to slip. Your tires still have enough traction to put power down, but they're also protesting loudly and have lost enough traction that the car has only just started to rotate. At this point you're steering with the throttle. A little more throttle, you lose a little more traction, the rear end steps out a little more, and you go wider. A little less throttle, the tires regain a little traction, the rear end comes back into line, weight transfers forward, and you tuck into the corner. At this point, steering input is almost less important than throttle input. Your steering wheel has set the line you want, and your throttle adjusts your position on that line. You can feel this when you take long curving on-ramps, with larger throttle inputs. Let off the throttle, weight rolls forward, there's more weight on the front (turned) wheels, and you take the corner tighter. Roll on the throttle, and you'll swing out wider. It's an interesting thing to get the feel of. |
Does that mean I am throttle steering ? http://i628.photobucket.com/albums/u...ps3eb3bee8.gif CERBERUS |
That's understeer, you're probably going faster than your traction will allow you to turn in. Inertia's a bitch. Don't hit the corner harder, push harder through the corner. The rear end will want to come around.
Keep in mind that getting it wrong can result in spectacular events taking place. Don't attempt if you're penned in by walls unless you know you can get it right. |
I can tune the car for oversteer with tire pressure but I'm slower (always correcting for fish tail). What would I do to be faster with oversteer ? And no I don't experiment with close walls LOL ! http://i628.photobucket.com/albums/u...ps3eb3bee8.gif CERBERUS |
| All times are GMT -4. The time now is 07:31 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
