First, be sure one of your keys is placed in the box properly. The chip should be in the circle of wire thingy. like this: http://i737.photobucket.com/albums/x...psd1bcc581.jpg Screw the top back on tightly, the key should not move in there. Next, immobilizer is this device sitting on the ignition (it is held on by clips on the top which can be gently pushed aside to remove): http://i737.photobucket.com/albums/x...ps037aab14.jpg The wire from the bypass that is in a ring, must be taped around the edge of the immobilizer like so: http://i737.photobucket.com/albums/x...pse2088de4.jpg Wrap it tightly around, and tape it REALLY well. You do not want that thing ever slipping off, especially if you are stashing it elsewhere in the dash (which is what I did). Be sure the immobilizer is connected to the original harness from your car. Plug the other end of the copper ring wire into the immobilizer bypass box (the blue plug). Then, plug the harness which runs from the immobilizer bypass box to the easygo module in correctly (see the wiring diagram). It should work now. Of course, you still have to do something about the steering wheel lock, I'll post something on that later. |
please let us know what you guys do about the steering column lock
A. Have a copy of your key made (a non-chip key, should cost less than 2 bucks). Mark the key about half a centimeter where it sticks out of the ignition, cut the key off at that point, reinsert and use needle nose pliers to turn it to the on position. Cover, and never touch again. B. Remove the entire ignition assembly. This requires some skill, as you must get that bolt off somehow (see this video [ame]http://youtu.be/rMv79GFUh-s[/ame]), or dremel through the cover folding it onto the steering wheel column (which is what I ended up doing in frustration). C. Remove the steering wheel lock itself. Now, this is something I can't entirely vouch for, but might end up being the best way for a clean solution. I figured this out after dremeling off my ignition assembly, so I don't know how easy it is to do when it is still attached to the car. I am currently travelling so I won't be able to post pics for a couple of weeks, but here is how it would work: Remove the steering wheel column cover. Take off the immobilizer. On the back side of the ignition cylinder (midway of where the key will be), there is a small hole with a button. The hole is hard to see, there are some metal prongs sticking out, it is not in those columns, it is a flat hole between them. You need to insert your key, and turn it to the on position (or it might be ACC, I can't remember offhand). In that position, use a pick or other narrow tool, and insert it into the small hole in the back. If the key is in the right position, the button will push in. Pull on the key, and the ignition will slide forward a little bit. Next, look for a small hole on the other side (you should be able to see it facing you as you sit in the seat). Insert a probe into that hole, and pull on the key more, the ignition should just slide right out. Now, look into the chamber where the ignition was, on the bottom there is a spring, and two pieces of metal that slide back and forth (this is the steering wheel lock). This is the lock. You may be able to use long narrow needle nose pliers to remove the spring and the metal pieces. Then reinsert the ignition and you should be good to go. |
I think I'll just stick to using a standard key..... /shrug
I am interested with the OEM look, what is the OEM panel part numbers?
can we buy a complete set from Subaru ? and place it into Scion? |
Finally put together my DIY for the EasyGo kit. It can be found here if you are interested. http://www.ft86club.com/forums/showthread.php?t=39313
I just installed it and can't start remotely because of clutch. |
I bought this and had it installed yesterday! It all works, EXCEPT the remote engine start doesn't yet. The guy said it'll start and then die and keep trying to re start. He has to talk to them at EasyGo to figure out what needs to be done. However, the push start works great and so does the keyless entrance on the handle! The locks also automatically unlock when you turn the car off...nice!
That looks simple and easy, but isn't that gonna bring CEL up? I heard someone got CEL because computer detected it as the clutch pedal is always pressed in. |
| All times are GMT -4. The time now is 08:56 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
