-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Engine Knock sound issue (https://www.ft86club.com/forums/showthread.php?t=32631)
microbionic 07-02-2015 11:53 AM
Originally Posted by Astroboy (Post 2307231)
What oil were you using
Past 3 changes motul 8100 ... had some castral and some royal purple in the mix before I settled on motul. All 0w20
Astroboy 07-02-2015 12:39 PM
Shit. I'm using motul 8100 eco energy
Sent from my LG-D850 using Tapatalk
BRZnut 07-02-2015 10:31 PM
What are your driving habits?
microbionic 07-02-2015 10:39 PM
Spirited but I do not think excessive. ..clean shifts.. will see redline on occasion.
Astroboy 07-02-2015 10:40 PM
That's weird. Did they say it was the oil? And when you said it was coming from the bottom, what exactly is coming from the bottom?
microbionic 07-02-2015 10:44 PM
You know as much as I do. there is no way to know what the issue is till they rip it down...if they rip it down. That is up to subaru ... oil is asked about as standard procedure. .. they dont want to pay for it.. so if I did not keep up with my oil changes... thay can deny me my engine repair .. my oil recipts have me right around every 7k so I should be good..... but wont know until we hear from subaru.
BRZnut 07-03-2015 06:24 PM
If it is what others have had, bet he spun a bearing in the lower end of the engine. There seems to be issue with oil starvation in the lower end causing rod knock and engine failure. At least that is what others have had happen to them on this board.
From what others have posted, if you get all the oil changes at the dealer, no issues with the repair being done under warrantee. If you do the oil changes yourself, the dealer will try every trick in the book to get out of covering the repair.
Hope all works out for you....Keep us posted!
microbionic 07-03-2015 07:47 PM
Yeah... im preparing for that conversation..
T182graff 07-06-2015 11:10 AM
Have you guys had any luck with this?
microbionic 07-06-2015 11:17 AM
No word from subaru yet for me.
T182graff 07-06-2015 11:42 AM
Good luck man,
I had the same issue with my car but my car broke down, the scion dealers said it won't be covered under my warranty.
microbionic 07-06-2015 11:43 AM
Originally Posted by T182graff (Post 2310979)
Good luck man,
Did they give you a reason
T182graff 07-06-2015 11:46 AM
They said it was the oil filter wasn't screwed on and that caused the oil loss. I told them I changed the oil for 2 years and nothing that can't be the case, they never pulled the codes or anything.
microbionic 07-06-2015 11:53 AM
Was ur oil low?
