Shut up and take my money!
We've used this setup in many s2k's, which makes similar HP and Tq numbers without an issue. Only time I have see any type of failure was from aluminum cases twisting under load. We always recommend to use a steel case.
Full Blown have quite a lot of experience with the 8.8 rear-end in the S2000 world, with examples running in the 8's and 9's
Nice to see this development taking place on the FR-S/86/BR-Z platform V160 or R154 swap could be interesting |
The speed with which the aftermarket has evolved for this car is pretty amazing. Gonna be a fun tuner car... :-)
We have no plans for a trans solution yet. We'll see how everything goes first.
at what HP/TQ does the OE one start to fail?
budi |
Id really like to see the stock trannys breaking point before id even think of a v160. 2-3x the weight maybe? And if i recall it was roughly 30" from the bellhousing to the shifter... Not to mention enlarging the tunnel would most likely be required (went thru all this with one of my mk3 supras)
Don't think I will be needing this part, haha.
i was wondering what about the axles, cause I'm worried about those after seeing E.kanoos 2j 86 blow them on the drag strip |
We are working with DSS to get the axles made
theres no way id pay 3000 for a ford rear end specially a 8.8 as soon as a good amount of torque hits it, it will go just like the scion diff, if i was to use anything other than a dana 44 pumpkin as used in the corvettes from the 60's on up to the 80's, it would be the ford 9 inch specially if your already customizing the pumpkin to fit under the car just my opinion but the dana 44 is alot more strong, i mean there is a reason why everyone love the 9 in.. the 8.8 doesnt handle much abuse same goes for gm 10 bolt rear axle both were fit under stock pony cars both are garbage in the pony world every one i know got rid of both axle asap for the ford 9 inch, or a dana 44 or for more power apps even a dana 60
we have tons of these kits on 2.0L-2.2L making 800-1000hp+ without any issues. These cars are going anywhere from 10's - 8.50's in the quarter.
I'm sure a lot of big block domestic guys are breaking these , but this has been tested and proven for what we are doing. |
| All times are GMT -4. The time now is 07:08 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
