John |
^^ I'll see about that when I finally order a tune (no point with snowy roads :D) :D
I figured as much, but I'm stubborn and will still try to make it run through a virtual machine. |
Go do a local tune. Always better than E tunes imho
Nothing against FA20club or Visconti, but they both know they can tune better locally than anything. Local tunes are PERSONAL tunes for YOUR car with your mods. Nothing beats that. Most do updates for life too when you buy a tune. |
Agreed especially since your in CALI, Evasive motorsports could help you out. Unfortunatly for me the closest tuner is about 7 hours so Fa20 or Visconti is the way to go for me |
@wparsons So, yes, it WILL work in a virtual machine. |
I would highly suggest just doing bootcamp ;) |
I'm trying to work out how the new Ecutek license system works.
I understand that owners can now flash back to stock, which allows dealers to flash the ECU .. but can they then go back to their Ecutek tune? What if I want to try a brzEdit or open source tune? Can I try them and then flash back to my Ecutek tune, or is that not allowed for some reason? I'd be a lot more likely to try Ecutek again if I knew it didn't prevent me from trying other alternatives, should I ever want to. I'd really like to hear from someone who has flashed an Ecuteked ECU back to stock, flashed a dealer (or other) tune over the top, then reinstalled their Ecutek tune. Is it just promises, or has someone actually done it? |
If your dealer replaces the Ecu or flashes it then your Ecutek licensing is gone. You then have to contact your master dealer and get with them to get you a new license. New licenses are only provided when proof of Ecu replacement or dealer reflash has been done. So if your Ecutek tuned, flash back to stock and use brzedit you will lose your license. John |
The dealer tools can see the checksum info and ram info in the Ecu. During larger warranty claims , aka motor Subaru of American will ask the dealer to pull up some info which will tell them if the car has a stock or modified flash. That being said the dealer can not flash over a custom Ecutek tune.. Only a stock a Ecutek flash. Most of the time the dealer has problems with their tools so if they attempt to flash over a custom tune they'd blame their equipment before pointing fingers - trust me I know. But the current recall replaces the Ecu not flashes I've had a few customers have their custom tuned ecus replaced under this recall already. John |
:thanks: |
Unfortunately, it means Ecutek is still not for me. I understand the concept of locking out competitors, but really good businesses don't need to do this. I don't care what software a tuner uses. People who buy a car and own their ecu should have the freedom to choose the best tuner available at the time (without paying a new license fee to Ecutek every time they want to try an Ecutek tuner). If this is a technical limitation and not a deliberate restraint on customer's choices, then Ecutek need to fix it. Either way, thanks but it's not for me. |
| All times are GMT -4. The time now is 09:24 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
