-   -   HKS Premium Day 2013: FA20 stroker kit and cams (https://www.ft86club.com/forums/showthread.php?t=28820)
Coheed 02-13-2013 02:04 PM
The cams aren't much larger than factory, but they are likely designed to utilize the different piston speeds of the stroker kit. That would make sense. But the aftermarket should have cams out soon that will not lose any power anywhere appreciable, and help hold the top end a little better.
12mm lift and around 270* duration should do quite well with the high compression. A higher duration cam with less aggressive ramp profiles can probably rev quite well on the stock valvetrain as well.
Levi 02-13-2013 06:39 PM
What I would like is increased compression, same capacity, more power/torque at high revs, don't care about low revs, "because race car".
86drift 02-13-2013 07:14 PM
I'm guessing the cams are for a turbo engine.
Because otherwise why would you bother changing them for such a small change in duration. I'm waiting for 280+ to be released.
bunny86 02-26-2013 06:58 AM
Apparently when testing a possible bore increase they found that there was not enough margin to do this safely, hence the stroker kit only.
JP 02-26-2013 07:31 AM
thats what darton sleeves are for ;)
Turbowned 03-21-2013 01:01 PM
^^ This. ^^ I would love to see a 2.2L stroker. I have difficulty justifying the cost of rebuilding an engine with all those parts for a measly increase in displacement. For example, I could spend $4k on a 7AG stroker kit for my MR2, which increases displacement to 1900cc using a 7A-FE block and 4A-GE head. Or I could just get forged pistons and rods for the 7A block and still have ~1850cc for about $1k.
*KID* 03-21-2013 02:57 PM
I would love to see some cams making peak power up to 220Hp.That be nice and hearing the cam notes on the exhaust exit
FAER 03-25-2013 01:47 AM
bore and stroke for a 2.4 OR AT LEAST 2.3 PLEASE...
Lonewolf 06-28-2013 08:36 PM
Any updates on this?
cf6mech 06-29-2013 05:58 AM
This engine will see a lot of development,....just stand bye.
NYCsubaruBRZ 07-01-2013 04:37 AM
What else is there to keep this car NA and get the most power besides this stroker kit, a tune, pulleys, intake, exhaust, downpipe, light weight rims, light weight flywheel, ditch junk in trunk, carbon drive shaft, bigger throttle body, headers, dry carbon exterior parts, light weight battery.
am i missing anything to make this car faster in a straight line?
i cant seem to find any other parts to make power
Hanakuso 07-01-2013 04:41 AM
Final drive
NYCsubaruBRZ 07-02-2013 04:54 AM
Originally Posted by Hanakuso (Post 1037051)
Final drive
so not much for NA right now
Turdinator 07-31-2013 03:05 AM
Final drive
Have a look HERE
(sorry to bring up an old thread, was looking for it for another reason then saw this post)
