we have just gotten a module to do this, easy as pushing a button. More information to come.
:w00t: |
For the rest of you running larger rear tires: do you notice the car being more difficult to rotate? I mean without the brake bias being shifted rearward. |
For performance, please dont stagger this car. No need to as there isn't that much power. And it is much more costly since you can't rotate.
Has everyone decided the "pedal dance" is a don't-run-without-it kind of thing? |
The pedal dance just turns off auto-redistribution and it brakes like a standard car allowing you to trail brake. If you're an semi-experienced track/autocross driver, this is a big deal.
The bigger/better tires shouldn't throw off the brake balance unless you stagger sizes or compounds as the level of grip ratio of front to back will be the same as stock, I believe. |
I Have also seen a Japanese module somewhere than disables this too.
In two cars, with three different drivers, on a fast autox course, the Pedal Dance induced ice mode. That was during comp runs. We all reverted to the regular disabling of traction and stability, no more ice mode.
It may work on tracks and time trails, but on a fast autox course, I would never do it again. |
I've speculated (without confirmation) that the stock brakes have a rear bias, based on sizing, when using the same compound front and rear. |
| All times are GMT -4. The time now is 11:04 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
