-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   The "Pedal Dance" testing (https://www.ft86club.com/forums/showthread.php?t=25494)
Spuds 06-06-2018 06:40 PM
Originally Posted by TorontoNat (Post 3095920)
Precisely. and when removed or faulty it puts the car in the mode I'm asking about.....
Are you really suggesting removing brake light functionality to enable pedal dance (if it even works)?
TorontoNat 06-06-2018 07:13 PM
Negative... I must be a terrible writer for you to misinterpret my question by so much... Read slowly next time maybe.
ok I will try and word this simply enough for you guys.
Can anybody tell me what is going on with the car when it goes into this mode?
How does it differ from the pedal dance if at all.
Also, this has clearly never happened to you before because when it goes into this mode the brake lights STILL work.
Maybe we are talking about a different switch.
TorontoNat 06-06-2018 07:14 PM
Originally Posted by strat61caster (Post 3095975)
Unlikely, pedal dance doesn't trip the abs light, you'll have to test.
Will do next time it happens.
Sphinx 01-15-2021 06:45 PM
Quick question - when you do the pedal dance, is there a need to turn on Track mode?
With the pedal dance, the only thing left is ABS, correct? EBFD, stability are off?
Headed to the track tomorrow morning.
CSG Mike 01-15-2021 07:19 PM
You won't be able to "turn on track mode", because the pedal dance overrides it. Once you're pedal danced, your track/tcs/vsc buttons should do nothing until you turn the car off and then back on.
Yes, only ABS remains. EBD, VSC, TCS, e-diff are all off.
Ultramaroon 01-15-2021 07:30 PM
I guess it's been a while since I caught up here.
Disconnecting the brake light switch would not only kill your brake lights, it would also keep you from actually doing the pedal dance because it's used along with the handbrake switch to enter the cheat code.
Ultramaroon 01-15-2021 08:21 PM
Not knowing your driving experience, I suggest some practice tonight to get a feel for triggering it. There's a lot going on in the paddock just beforehand. Might not catch the first time if it's not completely up to temp.
Sphinx 01-17-2021 12:33 AM
Experienced spec miata racer. So not used to ABS on track.
Ultramaroon 01-17-2021 12:42 AM
Oh, hell yeah. You don't need any of that stability shit. It won't kill ABS, though. :( I've never pulled the fuse but I'm not super aggressive.
Did you have any trouble triggering it?
Sphinx 01-19-2021 11:22 AM
Tried it in my driveway and it worked. It was too cold on Saturday to run laps - actually had snow in the morning.
I don't mind the ABS. At least it will prevent flat spotting tires. I need to get a set of spare rims and some track tires for it.
RedReplicant 05-26-2023 10:20 PM
This post is old, but somewhat related without starting a new thread.
Has anyone noticed that the car will give a higher, firmer initial brake pedal in certain situations - mostly when you've got something like a short but fast kink before a heavy braking area. It feels similar to MK60E5 ABS anti-knockback pre-pressurization.
This is not to be confused with the high, hard pedal where the car won't slow down that some people refer to as "ice mode", where the ABS is locking you out while it recovers. I can coax the car into that on demand and work around it easily, so it is a non issue. I've never experienced the other form of "ice mode" where the ABS deactivates in this car, but have in other cars.
Car is permanently pedal danced via Beastronix, ABS module is out of a 2020.
ammtx 07-31-2023 06:00 PM
I have a 2015 FR-S that has the Traction Control and ABS off. I replaced the ABS actuator and the rear-right Speed Sensor (code for the traction control), but the ABS and TC are still not working. So I changed the ECM... but it's still not working. Also, the fan is permanently on (no fan or cooling system codes). I'm looking for some sort of modification made to the vehicle, but I haven't found one. I checked at the ECM, behind the Instrument Cluster and at the Hand Brake, but I haven't found anything.
Does anyone have an idea what or where I should check next?
CSG Mike 07-31-2023 07:23 PM
I'd be curious to see some data traces for this!
slockin 08-01-2023 11:46 PM
I was fighting the "fan is permanently on" issue as well. Details in this thread. TL;DR that this was due to a faulty wheel hub causing the wheel speed sensor not to read.
Does your car show any codes? I'd check for codes in the ABS module as well if you have a scan tool that support it. Also, if you have a data logging device that communicates with the ECU via CAN (like an AiM Solo DL), you can have it display data like wheel speeds to verify things are working.
Good luck fixing the issue!
