-   DIY (Do-It-Yourself) Guides (https://www.ft86club.com/forums/forumdisplay.php?f=43)
-   -   Wheel stud replacement (https://www.ft86club.com/forums/showthread.php?t=21563)
Jaylyons1 06-05-2014 07:41 PM
Originally Posted by Dave-ROR (Post 711420)
9. Once all of them are removed you should be able to pull the hub assembly away from the car
This isn't going my way. Sensor 10mm bolt is off. 4, 14mm bolts from behind are off. Big 32mm axle nut is off. Am I missing something? This damn thing is not coming off!
Dave-ROR 06-05-2014 08:39 PM
Did you remove the sensor or just the 10mm bolt? You have to remove the sensor as well. You may have to hammer the axle out to free the hub assembly from the drum assembly.
Jaylyons1 06-05-2014 10:31 PM
Yea, I had everything removed. It really needed some lovin. I ended up having to pry it off with a flathead all around. The dirt/gunk made it difficult, but that one is done at least!
jarednoel 06-06-2014 04:16 PM
Just had a wheel stud replaced last week on the back. Just so you guys know, you don't have to take off the axel nut to expose the studs. There are two threaded holes on the rotor/drum that you can use to insert a bolt that basically pushes it out evenly if you alternate one after another. Just don't know the size. I think it's the same for the front IIRC.
qoncept 06-06-2014 04:52 PM
Yep.
I don't know the size either. I know I don't have a bolt that fits.
jflogerzi 06-08-2014 02:30 AM
Originally Posted by qoncept (Post 1782760)
Yep.
I was doing this with a member. What he did was used a larger washer and then a nut that threaded on. Then used an open end lug nut and used an impact drill and just tighten which pulled the stud. No need to remove the hub and the threads were perfect. This guy is smart :)
Fizz 06-12-2014 09:53 PM
No need to remove hub if you're fitting stock or slightly longer than stock wheel studs. But if you're fitting the ARP studs for example, you'll definitely have to remove hub. But yes, tightening the studs with an impact wrench is waaay easier and faster than doing it manually.
qoncept 06-13-2014 11:33 AM
I didn't have any problems fitting my ARP long studs with the hub in place.
Fizz 06-13-2014 12:57 PM
Rear as well? How did u manage to wriggle it in with all the e-brake mechanism in the way? My nismo stud were only slightly longer than stock and it juuust squeezed in.
qoncept 06-13-2014 01:25 PM
Oh, not rear. I only did the fronts.
Frs123 06-14-2014 10:56 PM
Originally Posted by Fizz (Post 1752931)
Finally got around to install my Nismo studs. The fronts were very easy, I just hammered the old one's out and used the nut and washer method to install new studs. As you can see they're only 10mm longer than stock studs, which is more than sufficient for spacers up to that thick. Even without the spacers on I was able to use my Leggdura 35mm nuts with space to spare....no need to run ugly open ended nuts.
I haven't done the rears yet because they wouldn't fit without removing the hub...and i was too lazy to do all that. Will do the rears next weekend.
Anyway these wheel studs are perfect for those who want something stronger than OEM but without having extra long studs sticking out.
http://s23.postimg.org/b1gc2458b/ima...ucmz/image.jpg
http://s23.postimg.org/n21s2ucmz/image.jpg
Where did you purchase the nismo stud?
Fizz 06-14-2014 11:31 PM
Got them from japanparts.com but I've seen frsport.com selling them as we'll.
Frs123 06-14-2014 11:32 PM
Thanks
texasbound972 06-23-2014 06:02 PM
Might be a stupid question or I missed it somewhere but, do I need to put spacers on with these apr studs? I don't want to put them in just for them to be too long and not tight. Thanks!
