That sucks. Can't tell you how many times I've taken my wheels on and off. The ARP studs are nothing short than amazing! http://uploads.tapatalk-cdn.com/2016...0d036aaf93.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk |
ARP should issue a recall then
Yeah. So, like, are ALL the old studs bad? I haven't had any problems with mine yet. Bought ~June 2013.
Wouldn't hurt for a wholesale customer of ARP to ask the question. @CSG Mike @CSG David? |
FYI, I emailed ARP to ask about the studs I bought in 2013:
so I had the same issue.. ordered from amazon... I have these lot numbers:
115566 packaged on 1/02/2015 -- ? (not sure if packaged date is right, hard to read) 112509 packaged on 9/1/2015 116509 packaged on 11/22/2015 117726 packaged on 12/16/2015 *120404 packaged on 2/04/2016* these work, BARELY. I felt a lot of resistance towards the bottom of the stud even though the lug nut would never make it that far I'd rather have a perfect product than "good enough". Hope this helps a few people out. |
I just finished installing my ARP studs. Thanks for the pictures. They were very helpful.
My biggest struggle was separating the hub from the e-brake plate. I ended up threading the bolts into the hub and hammering them to break it free. It always makes me nervous when I use a hammer on my car, but I couldn't find any other way. All my studs and nuts were a good fit without any binding. |
Is there a good alternative to ARP?
I'm basically looking for a stud and nut solution with higher durability than the OEM? Do not care about the extra length/racing things. |
Tools I'll be needing for this?
Sizes? Two of my studs broke off, I'm going to be swapping out. Thank you. |
| All times are GMT -4. The time now is 06:38 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
