Isnt that terrible for your bearing? How's it holding up so far? Do you remember what size slide hammer you used?? Trying to picture it in my head.. but i guess the axle nut would hold everything in place anyways rights? I gave up on my rear studs. Tried using a jaw puller and ended up breaking that. I think Ill just bring it to the shop when it gets a bit warmer. |
I used the OTC slide hammer (9 way?) off of amazon (should be the first one). I had another backup plan (after numerous youtubing and googling) to get the axle out and hammer on the hub and bearing to brute force it out, but thankfully didn't have to resort to that. Sent from my A0001 using Tapatalk |
Thanks for all of the useful info in this thread.
I wanted to report on my rear install from today. 2 important findings: - Axle nut is a hobag. The crimp was folded over too much for any amount of screwdriver/punch action to solve. Electric impact to the rescue! - Hub rusted to knuckle. No amount of PB Blaster and hammering worked. Probably damaged something from the hour of frustrated hammering. PB + a couple heavy hits with a hammer + 3-jaw puller ([ame="http://www.amazon.com/OTC-Mechanical-Grip-O-Matic-Puller-Reversible/dp/B0002SRGCU"]LINK to mine[/ame]) worked! Will report back if there are ABS or other issues (I didn't remove mine). The motion of the 3-jaw puller cleared the area where the sensor lives... so it didn't seem necessary. |
I totally agree with you about the axle nut being punched in too flat. I used a flat head and basically hammered and cut a slit in it and finally folded it up. That was the most troublesome and time consuming piece. Everything else worked easy so thank god! |
@Dave-ROR
I had to replace a front hub, and it looks like the bolts holding the hub to the knuckle have red loctite or similar on them so I put some on just to be safe. |
I wanted to follow up on my stud problem
check out this video, I am not the only one... [ame="https://www.youtube.com/watch?v=dnwnb8myWKo"]ARP Wheel Stud Problems with Lug Nuts ---- Scion FRS - YouTube[/ame] be careful a lot of bad ARP studs are on the shelves right now... make sure you triple check with long open ended nuts before mounting the studs... ask me how I know .... |
@bspec, ARP was very dismissive when I called them last month, blaming the nuts, but since then, and especially after this video I think that they realized they had a real problem and they sent me replacement items.
I was annoyed at first that they were blaming me for not mounting the stud properly. I actually had given up and bought short nuts instead. Now I am receiving the new parts, I'll have to reinstall one set of studs, lucky this time around they are front one. So for me I received 2 bad set of studs out of 5 ordered, all on amazon.com |
Ugh I have some ARP studs that were made in aug 15 for the graffiti car.. sitting in the garage but the lug nuts are at the shop with the car. Guess I'll head over to the shop today to grab a lug nut to test with since I planned on dropping off the hubs/bearings to get the press work done tomorrow (no access to my press currently).
Spoke to Zach at ARP this morning. He sent out 4 replacement sets and return label for the bad sets, no questions asked. He offered background about the die recalibration and long wheel nuts as well. The entire conversation lasted ~2min.
I should have the new sets tomorrow. |
For those who have mounted bad ARP studs, it may be tough to get them removed as usual extractor are rather short, I did my front yesterday and I was lucky enough to find 2 extractor that 'work together'. See below:
This extractor was clearly too short... https://www.dropbox.com/s/6zy0w103mp...0.46.jpg?raw=1 But luckily I had another extractor that I was able to place on top and it works perfectly https://www.dropbox.com/s/ia1xcpt5n6...0.23.jpg?raw=1 I just hope that they will "stick" as the hub are not designed to change studs often. Time will tell. |
Received replacement sets from ARP <24hrs after call. 4 perfect sets, machined and packaged in Feb'16, lot number in the 120K range.
| All times are GMT -4. The time now is 06:38 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
