-   AUSTRALIA (https://www.ft86club.com/forums/forumdisplay.php?f=20)
-   -   Mounting a Fire Extinguisher (https://www.ft86club.com/forums/showthread.php?t=21249)
nzer 10-29-2013 08:36 PM
Originally Posted by zombieite (Post 1301439)
So someone does make a mount! Awesome!
However, I've gone far enough down the road of making one myself that I'm kind of looking forward to it. Additionally, I have already stripped one of the seat bolt heads even though I was using a proper splined socket. They are just too small in diameter for how much torque they were installed with. Rather than drill it out on my brand new car, I thought I'd look into the console idea again. I removed the trim thanks to this helpful video:
http://www.youtube.com/watch?v=d8lrrchH5A4
And now I've made a Lego prototype of what I'd like to machine. The plan is to make it out of 1/2" 6061 Aluminum plate. But I have no idea what I'm doing with regard to materials or machining, so feel free to advise. The shape has to be kept as simple as possible, because I'm new to machining. A shaped plate with holes in it should be do-able. I realize those screws are angled in weird ways, so I am planning to try to cut some angled holes in my piece instead of just trying to force the steel to bend too much.
http://www.flickr.com/photos/zombieite/10564382234/
If you're going centre console why not just this http://www.ft86club.com/forums/showthread.php?t=15588
There's already two bolts under the centre console liner.
zombieite 10-29-2013 08:44 PM
I saw that and liked it, but the Big Bend Open Road Race requires a 2.5 lb extinguisher which is too big for that space. It's also pretty heavy, so my setup will have 4 mount points instead of 2.
zombieite 11-06-2013 02:56 PM
I moved this thread to the track forum. I have an updated prototype.
http://www.ft86club.com/forums/showthread.php?p=1316240
existensil 06-02-2014 02:21 PM
Sorry to revive an old thread, but how did you guys remove the bolts holding the passenger seat rails down? They appear to be E-TORX bolts and must have some thread locker on them as I was unable to break the seal.
My fire extinguisher (2.5lbs) won't fit in the center console so I built a custom brace to mount in front of the passenger seat and attach to the rail bolts.
Buying a breaker bar to try and get more leverage. Will that be enough? Currently using an 8mm socket, but figure I should get a proper E-TORX socket. Any idea what size the bolt is in E-TORX sizing?
Rumbaar 06-12-2014 05:56 AM
Make sure you use a eTORX socket, e10. As you'll most likely thread the nut if you use a normal socket.
sickmint79 09-16-2016 04:07 PM
i ended up going the bracketeer route. great option!
https://www.pointmeby.com/2016/09/16...keteer-review/
ka-t_240 04-18-2017 02:40 PM
Bump!
Any new options or ideas?
I liked the look of the one, but links are dead.
fuddbutter 05-03-2017 10:24 PM
I have an aluminium bracket on the front seat bolts, its fucking annoying!
I am thinking of putting nutserts into the floor, then mounting it to them
Also, CAMS now say the bracket has to be mounted with high tensile bolts...
Purist 05-21-2017 01:22 PM
Made an aluminium plate that bolts in using the original center console bolt holes. Extinguisher bracket mounts to the plate. Very securely bolted in and has passed scrutineering. Looking at it I'm sure it was designed deliberately.
http://i300.photobucket.com/albums/n...psmquqy4jd.jpg
Scrappydoo 05-21-2017 06:15 PM
Originally Posted by ka-t_240 (Post 2894000)
Bump!
I think Speedtech went into liquidation last year. Perhaps someone from NZ can confirm?
