-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Koni Suspension Components (https://www.ft86club.com/forums/showthread.php?t=19992)
jamal 11-01-2012 06:17 PM
The adjustment for those isn't on the top like with the inserts?
And TIC what do you guys have in the front?
Racecomp Engineering 11-01-2012 06:18 PM
Originally Posted by RYU (Post 533241)
Oh SNAP! So you're confirming there is adjustment? :party0030: :happyanim::happyanim:
I'm just assuming so since it's like that on most Koni Yellows. I don't think they'll have perch adjustment circlips.
Originally Posted by RandyP (Post 533260)
Are they supporting on car adjustment for the rears? The take shock off car and remove spring to adjust concept doesn't work for me.
On my Mini you need to remove the shock, but do not need to remove the spring from the shock. It's on the top you just can't get to it. It is a pain but not a dealbreaker. I'm fairly sure you can get in there through the top on a Subaru but I do not know how the Koni adjuster looks for this car (i.e. if you need their big adjuster knob or whatever). I have not seen it first hand so I hope TIC can shed some light on this.
- Andrew
jamal 11-01-2012 06:26 PM
Just looked it up. Adjustment is on the top and should be fairly easy to get to. Worst case you'd trim a little carpet to make access easier.
Did that sound dirty to anyone else?
It would be nice if ground control just sold the lower housings for the front. Then you could buy those along with a set of konis and not have to do any cutting. Not that it's that hard and at least you don't have to do it to all four like with the old WRX.
EZWood 11-01-2012 07:06 PM
FSD's would be awesome.
RYU 11-01-2012 07:23 PM
lol i was thinking the same thing
You're talking about the GC threaded shaft inserts right? The one that basically takes the stock Koni damper and adds height adjustability to it?
Circuit Motorsports 11-02-2012 02:41 AM
I just spoke with the 3 Koni reps today at SEMA - The first run WILL be Inserts only front and the shocks rear.
They are looking into a full strut up front but that will be determined in the future.
We will have something for you guys on Koni stuff and options here in the near future, hopefully maybe 4-6 weeks.
Turn in Concepts 11-02-2012 11:47 AM
The adjustment in the rear is easy to get to. Just pull the carpet back a bit. The fronts are also pretty easy, but with the original camber plates we have we can't use the adjustment knobs. The NEW (wait till you guys see these!) camber plates allow for enough room on the nut to use the provided knobs.
There is no perch height adjustment like on some koni shocks.
They work amazingly well with the RCE yellows that we have on the car. The yellows feel pretty good on the stock dampers, but used on the konis there is a heightened level of grip. The level of control over the stock dampers when hitting large bumps is amazing.
Tony
*KID* 11-02-2012 12:06 PM
nice KONI shocks :)
BTW what wheels are on that BRZ
Turn in Concepts 11-02-2012 12:14 PM
18x9.5 +30 Linea Corse Le Mans
RYU 11-02-2012 12:29 PM
Tony
Tony, this is exactly what I was hoping to hear. Thank you.
The stock damper on the RCE Yellows are good, not great (though still better than any stock damper/lowering spring combo i've ever tried on any car). The stock dampers can't handle big bumps or quick undulations in the road. It tends to bottom out and hit the bumpstops pretty quickly; in other words a significant lack of high speed compression/bump damping. I'm hoping you can confirm the Konis improve on this and can relay back to Koni that's the one thing the stock dampers are lacking. The rebound and overall control thru high speed bumpy turns is actually above average on the stock Showa dampers.
Racecomp Engineering 11-02-2012 12:54 PM
Feels good to read that! Thank you. :)
With Konis it's going to be pretty terrific.
- Andrew
Calum 11-02-2012 01:41 PM
- Andrew
I'm still deciding on what to do with my suspension. I've run koni yellows Before and thought the adjustment would be really cool. In the end though, I adjusted it and left it. Will you guys be offering preadjusted packages?
Racecomp Engineering 11-02-2012 04:33 PM
Yes, we would like to do that. :)
- andrew
*KID* 11-02-2012 04:53 PM
Do you have a side pic
