-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   BBK Fitment Database? (https://www.ft86club.com/forums/showthread.php?t=19756)
SkAsphalt 11-25-2015 04:30 PM
Originally Posted by liquidsky44 (Post 2455916)
Thanx but now I gotta add spacers. The wheel does not flush with the fenders with the cambers I'm running.
Well that is another problem and that is more due to the offset of the wheels than the BBK
lamawithonel 11-28-2015 01:04 AM
2 Attachment(s)
Sparco Terra
16x7 +50: http://www.ft86club.com/forums/showthread.php?t=57975
Essex/AP Sprint Front
Looks like it will fit! Clearance is about 2 or 3mm to the spokes and a good 6-10mm to the wheel weights (sorry, I didn't measure).*
*The template's hub looks like it was designed for a slightly larger bore, so this may be off by a millimeter or two. The right side bent a little more than the left, so the true measurement should shift outward, giving a little more room to the spokes and a little less to the wheel weights. If anybody can confirm this, it would be appreciated.
Essex/AP Endurance Front
Will not fit. The barrel is too narrow.
(Both pictures feature the Sprint template.)
ThatBlueBRZ 11-29-2015 04:52 PM
I've got front and rear Stoptechs BBK. Front is 328x28mm and rears are 345x28mm. I'm sure the fronts with 328x28mm will fit over a 17" wheel diameter without any rubbing from the callipers to the inner wheel well of the rims. I am just worried about the rears with 345x28mm. Has anyone tried the rears over a 17" wheel? Thanks in advance!
Race 05-10-2016 11:53 AM
I can confirm that the StopTech 328x28 ST40 front brakes clears the following two rims without spacer.
O.Z. Leggera HLT 17x7.5 ET35
http://www.tirerack.com/wheels/Wheel...ight+Race+Grey
Enkei Fujin 17x7.5 ET40
http://www.tirerack.com/wheels/Wheel...=Black+Painted
I didn't take pictures but there are adequate rim clearance and lots of spoke clearance for both wheels.
asnatlas 06-04-2016 02:22 PM
Originally Posted by F1point4 (Post 496441)
Would 5mm spacers work or would I need 10mm (or larger)? Also would I just need need spacers on the front or should I do all 4 corners with the same spacer size ?
asnatlas 06-07-2016 11:36 AM
Anyone know the minimum spacer size needed for the Stoptech Front 328x28 ST40M kit with OEM wheels ?
Eazy-V 08-06-2016 04:22 AM
Anyone running BBK on 17x9.5 +40 TE-37RT?
pcuerpo 11-07-2016 12:31 PM
anybody here has the Project Mu brake kit (FS44-F103B)? or anybody knows how they make those templates? need to find out how is fitment with the RPF1 18x8 +35 since i just placed an order on the PMU.. need to know if i should order another set of wheels if there will be fitment issues
byun 11-07-2016 12:37 PM
I test fitted the those on my Stoptech 355 BBK Front and it clears with a few mm of clearance, would definitely have to be careful where you place the wheel weights.
eromsdal 02-22-2017 09:28 PM
I'm not sure if I missed it or not, I'm still getting used to using the forums on my iPhone but has anyone confirmed fitment of the STI Brembo BBK with enkei rpf1's 18"x9.5" +38? Thank you
akatosh 04-03-2017 09:09 AM
AP sprint kit with 2017 OEM wheel (17x7 +48). Would fit with > 15mm spacer.
jbailey8748 06-26-2017 01:24 PM
Rpf1 17x9 +45 do fit the AP Sprint kit with 10mm spacers. On extended lugs of course.
3mm clearancehttps://uploads.tapatalk-cdn.com/201...019ab077ed.jpg
Sent from my Pixel using Tapatalk
Stang70Fastback 06-26-2017 02:42 PM
AP Racing 4-Pot Factory BBK clears both the 18x9+40 FF15 (HRE), and the 17x9+40 6UL (949 Racing) with room to spare. It also clears the stock wheels, as designed.
http://www.seriesblueadventures.com/...7-07-18-18.jpg
http://www.seriesblueadventures.com/...17/05/1212.jpg
SpartaEvolution 09-19-2017 04:25 PM
3 Attachment(s)
Thank you for making this thread! I'd like to add our fitment templates to the list:
Front:
4 piston 330mm
Attachment 158339
6 piston 355mm
Attachment 158340
Rear:
4 piston 355mm
Attachment 158341
