| Kamran |
08-09-2015 01:45 PM |
Originally Posted by HATED1
(Post 2351260)
@ Kamran did you need to shave/adjust the stock studs? Where are you located?
Not sure if I understand you but, no, I did not use these with the oem studs. I had increased my negative camber and tires were rubbing on top hat. So I needed spares, and these were not enough. So I took these off and bought thicker spacers. The studs in the picture came with the spacers and are longer. You don't want to use the oem studs with these, since you are supposed to engage 10 threads with the lug nuts, and with these spacers you can only get 6-8 threads of i remember correctly.
I m in Bellevue during the week and Seattle on the weekends.
