-   -   Smoke from new USA TRD exhaust (https://www.ft86club.com/forums/showthread.php?t=18812)
CBR600RR 10-03-2012 09:08 AM
Originally Posted by Sony (Post 473399)
Normal, my Perrin exhaust smelled and smoked something awful for the first 100 miles. I know for a fact that I did not leave any packing materials inside it ether. There is a lot of machining oils and residue left over inside a new exhaust from the manufacturing process, it's normal. The first 100 miles will consist of burning off and removing all those contaminants using the heat of the exhaust, it is a perfectly normal occurrence. It will also smell terrible for those first 100 miles too.
When I mentioned packing material inside the exhaust i did not mean 'packaging' material. I meant the fiberglass packing that is often used in the muffler as a noise reduction material.
The only way to remove the packing material inside a muffler is to cut it open. this fiber glass packing is very common in motorcycle exhausts.
travace 10-03-2012 09:23 AM
never knew they packed auto mufflers the same way. must be different in some ways cause motorcycle packing is made to be replaced
CBR600RR 10-03-2012 10:23 AM
^ it depends on the muffler and the packing inside the auto exhausts is generally made of a different material. As far as I know all OEM auto exhausts have no packing.
usually it is only the straight through auto mufflers that have packing. (hard to call these types a muffler)
now that I think about it the TRD muffler might very well not have packing inside. but the oils from manufacturing will make smoke too, but I would think that the smoke from oils would burn off very quickly (like 5-10 minutes of being at operating temp) as opposed to the smoke caused by packing.
jadewbj 10-03-2012 12:12 PM
Yeah, this is totally normal. It is the filling inside the muffler that smokes.
Verge 10-03-2012 01:36 PM
Originally Posted by DaveFTW (Post 472916)
I just got the exhaust installed from my local stealership and after leaving the dealership someone else on the road told me there was alot of smoke coming from the exhaust.
I immediately pulled over called the dealership back and asked if this was normal or should I come back.. they told me dont worry its normal you just need to run the engine...
my question is, is it really normal for new exhausts to smoke like I dont have oil, AND it smelled like burning plastic...
My thoughts are an idiot mechanic didn't take out some of the bubble wrapping.. :sigh: help.
Vids please. Still deciding if i should wait fir this or get the evo3
Touge Factory 10-03-2012 04:33 PM
Completely normal.
Draco-REX 10-03-2012 04:37 PM
Some smoke is normal. Clouds of smoke is not.
MarkRacerX 10-03-2012 04:59 PM
Same thing Freaked me out buying my 11' STi w/ SPT catback installed leaving dealership taking it home, white smoke , smelled bad, but was briefly within 20miles or so.
Now, Lets Hear it Roar !!!
FRSnCLN 10-03-2012 05:03 PM
im putting my trd on tonight. ill try and get a sound clip up.
