(Open Box Deal) Ohlins Road & Track Kit
Open Box Deal currently going on for the Ohlins Road & Track Kit for the BRZ.
Price: $1980 Email us info@sakebombgarage.com for any questions or details! https://www.sakebombgarage.com/ohlin...baru-brz-2012/ Features: - DFV (Dual Flow Valve) - Corrosion salt spray tested to ISO 9227 - 2 year warranty - Single bleed/Preloaded spring adjusters - Fully re-buildable w/dust-covers - Spring Rate: Front: 50 N/mm Rear: 50 N/mm Front (McPherson Strut): - Single bleed adjuster - Spring preload adjuster (20 mm lower than standard) - Coil Springs - Dustcovers - Use with original top mounts Rear (Conventional Shock Absorber): - Single bleed adjuster - Separate spring preload adjuster (20 mm lower than standard) - Coil Springs - Dustcovers - Use with original top mounts https://hosting.photobucket.com/imag...overs_kit.webp https://hosting.photobucket.com/imag...Kit_BRZ_3.jpeg https://hosting.photobucket.com/imag...Kit_BRZ_2.jpeg |
| All times are GMT -4. The time now is 02:04 PM. |
User Alert System provided by
