-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   Non-Coilovers options for track use (https://www.ft86club.com/forums/showthread.php?t=152700)
Flat Black VW 03-05-2023 02:53 PM
Hi all,
My race team has a 2013 FRS we are running and we currently have rebound/height adjustable MCS Coilovers. One of the series we run (ChampCar) does penalty points based on mods, and these coilovers score us a ton of points and penalty laps.
We are looking for a sort of cup kit alternative that would save us the points for when we run Champ. I don’t see any full kits, so am mostly wondering if anyone here has experience with different shock/spring combos on track.
Thanks!
Kelse92 03-06-2023 03:37 PM
I don't know a lot about ChampCar rules so is the ride height adjustability the problem? Spring changes? Both? Multiple line items?
Bilsten makes a pretty good OEM replacement shock you could probably get that is non-adjustable to save points, but you'd need to go back to stock springs (or other aftermarket lowering spring) also.
You can then decide if you want to use or not use camber plates etc, but at least you would probably save some points for non-adjustable perches and non-adjustable shocks.
Someone that knows ChampCar rules in here may have some better ways to optimize but those are just a few ideas
M0nk3y 03-07-2023 09:19 AM
Originally Posted by Flat Black VW (Post 3571340)
Hi all,
Thanks!
I would contact Jonathan Lugod at Shaftworks and customize a set of non-adjustable valved at the specific rate you're planning on running.
I know personally he's done this for an NA Miata running within Champ and that team has been more than impressed with the change.
JDMChris 03-07-2023 01:37 PM
https://shaftworksusa.com :party0030:
strat61caster 03-07-2023 04:01 PM
Could you switch perches and springs on the MCS and save enough points to make it worth keeping 'em?
The way the spring rules are written are wild, no idea what they are trying to accomplish other then making replacing sagging springs on an old car with readily available H&R or Eibach springs valid (like old specE30 kits, which got replaced with linear rate springs a few years ago apparently), which like, you're hitting a racetrack, a set of Eibach/Hyperco 2.5" springs are way cheaper then oem style 90mm lowering deals and they can accomplish their goals with just the spring diameter line and remove the rest.
While I'm a happy shaftworks customer seems to me Koni Yellows might be a good choice unless you take significant points for the rebound adjustment and are looking for non-adjustable, which Bilstein is pretty much the only quality option for this car that I know of.
rice_classic 03-13-2023 01:44 PM
Are you allowed a spring change without penalty?
The Bilstein B8+Eibach Sportline spring is an effective combination. Non-adjustable and non-height adjustable.
GrandSport 03-20-2023 03:56 PM
This. Why not just rebuild/revalve/respring OEM to whatever you run your coilovers at?
If that's not allowed, I'd strongly recommend looking into cheating lol. Just spray them with WD40, rub them in a little dirt and paint the springs OEM color. lol
