My look at the whole thing is, if you're getting an aftermarket header with a high-flow cat, you're already illegal because you're tinkering with emissions related parts. So whether you choose to go with a cat-less or high-flow cat header becomes a preference thing. I went with cat-less because from doing enough reading over the years from peoples opinions and thoughts on this, I came to the consensus that there isn't much of a smell if any, and that there was slightly more gains to be had. Since I was sticking to NA, I made my choice. I have no plans to ever touch my front pipe, nor ever go to a high-flow cat in that department. The smell, alone, would turn me down. |
In any case, the reason we got into this topic was because of exhaust smell. And I was saying that I don't get any smell once warmed up. I was actually thinking I'll experiment for fun when I get home one day. I'll idle the car for a bit, get out, and see if I smell anything and how bad it is. Because the truth is, I hate exhaust smell and I hate to put others through that as well. That is why I was very careful about choosing my exhaust and took a long time to decide. I was looking for best gains through the power band, little to no smell, OEM+ like sound quality and quietness. I've never had an issue passing emissions testing with my setup either for the past 3 years. I live in southeast PA, so YMMV. |
Get a friend or family member to drive your car while you drive behind it in a different car with your window down. Only way to really experience/verify if it stinks or not.
I never said anything about full throttle pulls, but rather I meant city cruising (25-45) speeds.
Politely disagree that attempting to check for smell at idle will give you "most of the story." |
Smelled many WRX/STI car that are catless . I don’t think it’s worth it, you need at least one cat. |
the secondary o2 sensor is placed after just 1 cat because it also aids in correcting the afr via fuel trims during cruising, and the first cat is already more than enough for the o2 sensor to measure different from the first, so that the ECU thinks the cat is working Also placing the o2 sensor after the second cat would bring it much further from the exhaust valve and also close to ambient air which then makes it useless to perform afr adjustment the 2 sensors in oem tune try their best to keep afr at precisely around 14.7 during cruising because that s the afr that produces less pollution when coupled with catalyzers When i tune this car, i disable completely the secondary o2 to the point that you can rip it off and the ECU doesnt care, and offset the primary lambda to get a real cruising afr of 15.5 or leaner, a thing impossible to obtain when on oem tune |
| All times are GMT -4. The time now is 03:37 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
