If you owned or drove a stock Supra on the track..
Currently own a base gr86 and considering a manual Supra. Car is 75% track duty.
Does a MkV Supra handle better or worse than a stock GR86, asking purely about entry speed and how much of it can carry through a corner. Not asking about lap times or how hard it can accelerate out of a corner if you did slow entry fast exit. Lets say GR is on the Pilot4s (mine is on Champiro) and Supra is on whatever it comes with from the factory. It is about 700lb heavier, wider tires...maybe higher quality suspension components.. maybe not. I am not sure if the chassis is better or not either. If anyone knows and has experience with both on track please let me know. |
Haven't driven one, but:
1) it's going to be somewhat track, corner, and driver dependent 2) No reason to expect that a stiffer chassis with much better weight distribution (51.5/48.5 for the Supra vs. 55/45 for GR86) and a lot more front camber (-1.75* Supra vs. 0* for GR86) and much wider tires (255/275 Supra vs. 215 GR86) should handle any worse than a GR86 on corner entry despite weighing ~550 lb. (not 700 lb) more. |
I have driven a pretty much bone stock supra on track quite a few times.
They are great cars, and I would love to own one, but a few compromises I would say: - Visibility in one is terrible compared to the 86 and the seating space is a bit tricky. I am 5'5" and I am more torso than legs, to get the proper position to reach the pedals and the steering wheel with my helmet on I nearly hit the sun visor. I suspect if you are tall you would have the opposite problem, so definitely take your helmet and sit in one before buying. - The wind buffeting is abysmal. Your first mod should be verus wind deflectors if you go out on track. - The handling is good but the suspension is a bit softly sprung. I have driven it's sister car (the M2 Comp) stock back to back with the Supra and liked the suspension package on the M2 much better. If I owned a Supra (which I do think is still the better of the two because of the weight/low COG) I would definitely be putting a good set of coil overs on it for track use. - I don't know how hard you drive, but if you plan to tune and turn up some power and drive it hard on sticky tires, I think the car starts to have some cooling problems and you'll want to upgrade that stuff. If you're just lapping/hpde in a cooler climate you should be OK. |
No experience with either on track, but I'd also consider consumables like tires, brake pads, etc.
I'd think the Supra would be much more expensive to run as a track car than a GR86. Not sure about your situation, but it might be something to factor in beyond the performance aspects if costs would lead to less time on track. |
A little bit confusing here, grip and handling are not the same thing in my world. A car can be fast and grippy but handle like a dog, and vice versa.
I am a stickler for weight though, and Supra is too heavy for me. Maybe the 2.0, but it's still 3200 lb., and also unsure about all the "BMWness"... |
There's just no way to escape the weight. |
The big tires can generate larger spikes, but not sustain the cornering. It's just physics. Or maybe the lighter cars are being underdriven, or taking a different line to preserve momentum. Tons of confounding variables. Stock tire size vs stock tire size, the Supra will win, but when both cars are upsized to what reasonably fits in the stock body, the Supra just has zero chance. I have an immense amount of data with this specific comparison to back up the observation. Believe me, I'd love for heavier cars to corner harder! I spend a lot more time in heavier cars than I may talk about here. |
With downforce all bets are off of course. Same amount of downforce on a lighter-weight BRZ should kill... |
| All times are GMT -4. The time now is 06:25 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
