any more pics of this car? from straight on front and back
car is now on KW V3s, dropped about 1.5"
hope you don't mind that I posted the pics you sent me D1cker https://sphotos-a.xx.fbcdn.net/hphot...27603050_n.jpg https://sphotos-a.xx.fbcdn.net/hphot...54224557_n.jpg front fitment, now w/ Whiteline Com-C and OEM 14mm bolts https://sphotos-a.xx.fbcdn.net/hphot...74430652_n.jpg |
Sent you a message about the clearance of the front caliper and you never answered. How much clearance do you think the front caliper has between it and the wheel? Reason im asking is because i want to get this offset but i have a ap bbk.
^ if you look at pics of others w/ 17x9 +35, the front actually pokes out about 5mm w/ 0 camber, if you add -1.5 to -2 degrees, it sits flush w/ the fender
I did try the essex template against my spare wheel and it looks like it will just barely touch. With a 3mm spacer it would clear but I am not sure if the componets will flex under hard corning and make contact. A 5mm spacer should be enough though! |
this brake clearance issue is just if your running a big brake kit?..i think in STX you cant run a big brake right?..anyway im just about set on getting these RPF1s in 17x9+45 so it would be good to know
this is the exact setup i want. it's great track material!
http://www.ft86club.com/forums/showthread.php?t=23662 -Chris |
i can't yet :(
-Chris |
| All times are GMT -4. The time now is 12:45 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
