Asphalt with 17" Black RPF1!! (HAVENT SEEN ANY!!)
This is what I am planning to do.
17x9 +35 on asphalt FRS. I havent seen anything like that yet. Can anyone do a quick photoshop for me or post any picture of that if there are any?? I do think it will be a good combination with the tint valenti tail light! I would like to know how it looks like. Thanks!!! |
found these pics in another thread. hope it helps
http://www.ft86club.com/forums/attac...1&d=1350068536 http://www.ft86club.com/forums/attac...1&d=1350068563 |
Thx!! Now I do have an idea how its like
those are not x9's though. it will look much better than that
Anyone have pics of Asphalt with Silver/Gold rims similar to these?
If you plan on getting just springs, versus coilovers, I would suggest you look into a 3-5mm spacer and go from there. |
need confirmation on wheel set up
I plan on buying 17x9 rpf1's with a 35 offset and plan to run at least 245-40 tires. Suspension wise, i have swift springs comming in, and i was wondering if i will have any rubbing issues regarding me hitting my fender liner or any suspension parts on full lock? If this set up wouldn't work i was then gonna buy the 17x8 nt03's with 245's. So my worry is the same, if there would be any rubbing on the fender liner/suspension parts on full lock etc.
It should fit fine. Shouldn't have any issues with the fender unless you are going fairly low - camber and tire size will determine this. The +35 will poke slightly at that drop unless you add camber. 245/40/17 is a good size.
The +45 will rub the tie rod at full lock. There is a whole thread on the 17x9 RPF1. http://www.ft86club.com/forums/showthread.php?t=15160 |
| All times are GMT -4. The time now is 12:45 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
