Aim Solo steering angle reading
So I just got my car aligned and everything is fine except the wheel is slightly off center. Before taking it back I decided to see how off it was as it might be helpful for getting the wheel back to center.
To my surprise with the wheel a bit off center to the left it was reading 0.9 If I move it every so slightly from where the alignment tech put it I get 0.0 but are talking like less than an inch of movement. Trying to center it only made it "worse" If my wheel is dead center I am seeing 3.3. The car and aim solo along with the alignment are all new to me so I have no clue if this is normal.. What sort of steering angle readings are you guys seeing on your aim solo's with the wheel straight. |
Is it possible your steering wheel was swapped out at some point and is off by a tooth or something? That's the only other thing I can think of that could be the cause, though I haven't really looked at my steering angle data to be honest
Make sure the steering rack is centered, and the alignment is such that "straight" on the wheel is 0 thrust angle.
I might just bring it back to have him center the wheel and make sure the steering angle reading is 0. I assume if he centers the wheel and it shows beyond 0 it means the rack is not centered |
Reading 0 now with the wheel straight after the tech adjusted
| All times are GMT -4. The time now is 11:56 AM. |
User Alert System provided by
