-   -   Will this fit? (width, offset and tire size Qs) (https://www.ft86club.com/forums/showthread.php?t=15007)
Rabble 05-17-2013 06:05 PM
Originally Posted by Slick (Post 942262)
For sure, it's only a half-inch wider than the stock wheel. No problems with fitting the OEM tire.
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
Slick 05-17-2013 06:08 PM
Originally Posted by Rabble (Post 942278)
What's the question?
Rabble 05-17-2013 06:17 PM
Sorry,
Will these fit on the car? the offset is like +35 compared to +48 stock
jshadeck 05-17-2013 06:21 PM
Originally Posted by Rabble (Post 942309)
Sorry,
That link is 17x7 +48 rims..
Rabble 05-17-2013 06:28 PM
Oh, where it says 17x7 you have to pick the other one from the drop down. Tire rack is weird like that.
jshadeck 05-17-2013 06:30 PM
That shows me a 17x7 +38
Rabble 05-17-2013 06:32 PM
Those are the ones.
jshadeck 05-17-2013 06:38 PM
Originally Posted by Rabble (Post 942349)
Those are the ones.
Just making sure, u confused me asking about stock tires on a 7.5" and mentioning a 35 offset.
17x7 +38 will be the oem rim size but will move .4" outwards due to the offset
Rabble 05-17-2013 06:39 PM
Cool, Thanks!
2point0 05-17-2013 06:43 PM
Sorry,
The wheels you linked are 17x7 in either +38 or +45. They would both fit just fine.
They list 18x7.5 in the same offsets, but that would still fit with no issues. Just can't use the stock tires in that case.
Edit...I lag, looks like someone beat me to it.
abling2 05-19-2013 07:29 AM
Im planning to buy wheels and tires specs are 18x9.5 +38offset with 255/35/18 tires. what lowering springs would be safe for me to run on without having to roll fenders and zero rubbing issues? thanks :)
ill86 05-19-2013 12:06 PM
:-) there are 33 pages of great replies here. Read up and choose your own. That's part of the fun!
FRSTRM 05-19-2013 01:14 PM
3 Attachment(s)
Apologize if these sizes have been touched upon before - wheels really aren't my specialty. I'm considering the Platinum Widow 18"
Brand_____ Platinum
Model _____Widow
Item Weight______30 pounds
Product Dimensions_____18 x 18 x 8 inches
Exterior_____Matte Black with Gloss Black Inserts
Manufacturer Part Number_____212-8818B
Construction_____1-piece
Rim Diameter_____18 inches
Rim Width_____8 inches
Bolt Pattern (Number of Holes)_____10
Bolt Pattern (Pitch Circle Diameter)_____100 millimeters, 4.5 inches
Offset_____42 millimeters
Backspace_____6.15 inches
Hub Bore_____73 millimeters
How would these fit on stock? I may lower in the future, but not by much.
EDIT: I would also likely get 225/40 tires - would this work as well?
:thanks:
Attachment 37825
Attachment 37826
Attachment 37827
(This isn't my car - I own a Firestorm, but this is how it looks on an FRS [images show 17" wheels])
jshadeck 05-19-2013 03:01 PM
Brand_____Platinum
Model_____Widow
:thanks:
Attachment 37825
Attachment 37826
Attachment 37827
30 pounds? 😬
