-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Front lower ball joint nut removal tips? (https://www.ft86club.com/forums/showthread.php?t=149872)
Ohio Enthusiast 06-01-2022 05:31 PM
Originally Posted by Matt93SE (Post 3526780)
Modern Japanese cars use torque on the nut to put some tension on the threads and keep the nut from loosening. Murican cars (and earlier Japanese) use a castle nut and cotter pin at much lower torque.
The Twins use a castle nut and cotter pin. Would that still benefit from your explanation?
Matt93SE 06-02-2022 09:46 AM
Strange. neither my 13 nor 17 had castle nuts. they just had a standard flange nut with a cotter pin.
But yes- any ball joint or tie rod end that uses a tapered pin will work this way. shove the pin farther into the taper and it won't spin as easily. Once the nut is removed, then wail on the side of the knuckle around the pin with a hammer. a few good whacks will deform that taper just enough that the pin comes loose. voila.
Ohio Enthusiast 06-02-2022 10:04 AM
Oh, I might have incorrectly interpreted the picture from the repair manual...
series.trackday 06-02-2022 12:13 PM
Nope, mine is a '17 and it had castle nut + cotter pin on a tapered shaft. Matt's may've been replaced at some point with the incorrect nut?
Matt93SE 06-02-2022 12:16 PM
Very well coulda been. used cars and all that jazz.
series.trackday 06-02-2022 12:35 PM
That's always the way. I replaced mine with the setup from SPLParts, so now it's just a locknut. I put some paint on it to detect if the nut slips.
Matt93SE 06-02-2022 01:19 PM
Same here. I alternate white, orange, and yellow paint pens as I do service work so it's easier to tell which mark is the latest.
Grady 06-02-2022 07:32 PM
Originally Posted by series.trackday (Post 3526361)
"If I ever met the engineer that designed this I'd give them a good choke."
Who the hell comes up with an integral ball joint without a keyed shaft or something?
Nothing wrong with the design, almost all ball joints have been that way forever. Sounds more like a corrosion issue or most likely an improper install issue. I have never had the taper fit break free before the nut. I would have tried to retighten or even overtorque the nut then heat/penetrant to remove.
Cross threading the worlds free loctite.
