-   Want-To-Buy Requests (https://www.ft86club.com/forums/forumdisplay.php?f=84)
-   -   WTB: FRS Rear Wheel Bearing & Hub Assembly Set & Brake Caliper (https://www.ft86club.com/forums/showthread.php?t=149366)
black.jmyntrn 04-05-2022 07:41 AM
if you have OEM, used preferred in good condition. Im converting my Prius to AWD and need these to convert the UX250h rear end to 5x100 for the Prius. I might be able to get away with using my rear drum set for ebrake. If you have this as well, I might be interested.
If you have OEM calipers and other I'd like those as well.
e1_griego 04-05-2022 11:06 PM
Where are you at? I just pulled rear hubs off my car thinking that I had a failed wheel bearing but they feel totally fine (womp womp).
Smacked the studs in one of them so a couple need replacing but they feel just fine otherwise. 87k miles on them.
