-   -   Jong's 2nd Gen BRZ (https://www.ft86club.com/forums/showthread.php?t=149353)
jongers 05-05-2022 03:47 AM
Couple updates!
Interior CF bits:
https://i.imgur.com/KsM8Q0R.jpg
Ordered Reman'd STi brembos F+R (2014 STi).
https://i.imgur.com/OsKutqK.jpg
Waiting for the rear to come in. Also picked up some DBA 4000 F+R slotted rotors, StopTech SS brake lines, and getting hooked up with some DBA SP500 pads for now (hopefully some project mu CR's in the future, but I've been enjoying a brake squeal-less life).
Hoping to get it installed next week, will post part #'s if everything goes smoothly.
jongers 05-09-2022 02:32 AM
Bought some high temp brembo decals off amazon. The smaller sized ones didn't fit well with the rear calipers, so I ended up just using one of the included logo stickers.
https://i.imgur.com/fdcEHyq.jpg
The rest of the items
https://i.imgur.com/QDJPCnP.jpg
Going to spray a couple cans of caliper clear coat tomorrow and hopefully install later this week (still need to pick up some brake fluid).
villainous_frx 05-09-2022 03:20 AM
DBA T3 are the business, nice build so far!
jongers 05-10-2022 10:54 PM
Looks like 14 STi Calipers Front and Rear were a direct fit! My buddy handled the install as I sat around watching youtube on my phone until the blakes needed to be bled.
Again, list of parts used:
14 STi Brembos from RockAuto (F+R)
DBA 4000 T3 Front Rotors (1st gen w/ PP Brembo Sizing)
DBA 4000 T2 Rear Rotors (1st gen w/ PP Brembo Sizing)
StopTech Stainless Steel Brake Lines (F + R for 1st gen)
DBA SP500 Pads
Only thing I needed to replace were the caliper bolts - had to make a quick run to O'Reilly's at 10PM to pick them up. Link to the bolts.
You'll also want to relocate the bleeder valve on the front calipers.
Fronts:
https://i.imgur.com/WTHTATy.jpg
Rears:
https://i.imgur.com/cOLslJT.jpg
Installed:
https://i.imgur.com/l82pvkn.jpg
https://i.imgur.com/4gerUON.jpg
Will have to report in later on how I feel about the changes. This apparently messes up the brake bias by 4% towards the front.
sds 05-12-2022 04:34 PM
DBA SP500 Pads
Any clearance issues with the knuckle?
jongers 05-12-2022 07:24 PM
Zero issues. It was a direct bolt on except for the caliper bolts I mentioned above (stock has a 1.25 mm thread pitch - the STi brembos require a 1.5)
Yoshoobaroo 05-22-2022 08:47 PM
The fitment looks excellent with the Volks. How's your wheel clearance on the outside and inside with that width and offset? Did they fit with stock suspension or were the coils too wide on the stock springs? Do you have any shots parallel to the sidewall so we can see the tuck/poke?
jongers 05-23-2022 11:51 PM
Thanks.
They barely fit on the inside with the stock rear struts
https://i.imgur.com/bjhYvGP.jpg
Don't have many good pictures, but here's some photos when it was still on stock suspension. A bit of poke without any drop/camber.
https://i.imgur.com/6y9oS8q.jpg
https://i.imgur.com/Z49uzYc.jpg
https://i.imgur.com/jIgTzIL.jpg
jongers 06-05-2022 11:50 PM
https://i.imgur.com/M7Otc4p.jpg?1
Update on the STi brembos - Everything's felt great with the upgraded pads/rotors/calipers. Haven't noticed much of a difference in the brake bias, but definitely a huge improvement in initial bite and overall stopping power. Dealing with some random squeeling at low speed braking. Also, the amount of brake dust with the new combo is making the white wheels look hideous :thumbdown:.
https://i.imgur.com/B9aQBiK.jpg
Buddy of mine was getting rid of his seats and I was able to get a RS-GK for the passenger side! The bank account hurts, but interior symmetry inc :wub:.
Now, time to see if the nagisa passenger side rails or evasive rails are in stock.
jongers 06-25-2022 03:15 AM
Passenger seat installed + Christmas light dash activated!
https://i.imgur.com/TQtr9U7.jpg
https://i.imgur.com/hNj7cR4.jpg
Going to pick up a resistor and get it installed later.
I'm thinking that due to the passenger seat sensor, I might run into some issues. Hoping to avoid having to lift open the seat cover and peel off the sensor/membrane.
jongers 06-29-2022 01:47 AM
Quick update w/ the Passenger Side SRS/Airbag Light after seat install.
The same 3.3 ohm 1 watt resistors I used for the driver's side did not get rid of the lights. The passenger seat is still causing my dash to light up with warning messages.
Not looking forward to tearing apart the stock passenger seat to get the seat sensor + heating pad if this requires the same fix from the first gen.
If anyone has any suggestions, TIA.
SuperTom 07-01-2022 06:00 PM
It sucks im 1st gen but could never get my light to go away from the passenger seat. And yes I tore apart my stock seat to take out the butt sensor and put a seatbelt filler in the female recepticle. I eventually just took out the speedometer and put a piece of black tape over the light
Your seats look great by the way
jongers 07-01-2022 08:00 PM
Thanks! Bummer. I don't really wanna tear up my stock seat so I might look for a seat from a wrecked car in the future to experiment on.
Sadly, the way the SRS error is displayed on the LCD that is shared with vehicle information (temps, mpg, manageable screen) means the black tape fix won't work.
Maybe this is an excuse to get a MoTec in the future!
jongers 07-03-2022 10:59 PM
https://i.imgur.com/dSjPDGb.jpg
https://i.imgur.com/at1DG0T.jpg
https://i.imgur.com/L2drRmi.jpg
https://i.imgur.com/cLom9zs.jpg
Last time I'll be washing an uncoated car!
Got an appointment to get the car coated with Gyeon (Infinite base type 2 + Infinite top coat) from a local detailer next week. Hopefully the car will only require a 1 step correction, but we'll see how that goes. Had Ceramic Pro (silver) on my previous black 86 and the minor protection it provided coupled with the ease of maintenance made it well worth it.
Will also be product testing (getting free partsssssssss) some FLCA this week :happyanim:
