-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   Dot pattern on rotor (https://www.ft86club.com/forums/showthread.php?t=149193)
86league 03-21-2022 03:00 PM
What would create a pattern of dots like this on a rotor? Is this ABS?
https://www.ft86club.com/forums/pict...ictureid=12784
Off a friends car - rotors were replaced due to development of moderate shudder. Centric premium rotors for the Brembo (PP) brakes, XP10 pads - using enduro 200 TW tires (SX2, RS4).
Trying to figure out what caused it and prevent future shudder.
Thanks!
EndlessAzure 03-21-2022 03:12 PM
Looks like pad overheated and deposited material on the surface. The pattern seems indicative of ABS like you mentioned.
Does your friend use a lot of ABS in their driving style?
rice_classic 03-21-2022 08:34 PM
Ditch Carbotech and never look back. What you have there is an uneven transfer layer, an unfortunate characteristic of carbotech pads and yours looks like it was induced by ABS, possibly while the transfer layer was initially being laid down.
Rotors fine though. I solve this by putting a really harsh/aggressive pad and dragging the brake a bit while everything is cold and it cleans it off. But you could just buy new pads and rotors as well.
86league 03-21-2022 09:31 PM
Not sure how much ABS - I think everyone in my group of track friends are trying to limit ABS but I'm sure none of us can say we completely avoid it.
gcmak 03-29-2022 10:41 PM
Can't tell the thickness of the rotor and/or if there's a lip but that's just pad deposits/smearing from slightly overheated pad materials. This can be scrubbed off with some aggressive brake pad bedding / re-bedding, turning/resurfacing of the rotor, some work with a scotch brite pad, etc.
As long as the rotors are still within spec on thickness and not truly warped, they're totally good.
As others have kind of stated, you've found a thermal limit to part of your brake setup. You can keep your setup and adapt as a driver, or start changing parts. A combo of both is likely the best outcome.
CSG Mike 03-30-2022 06:21 PM
Looks like overheated pad.
get a higher spec pad.
