-   BRZ Second-Gen (2022+) — General Topics (https://www.ft86club.com/forums/forumdisplay.php?f=98)
-   -   Mirror Tap for Radar Detector DIY (BRZ Gen II) (https://www.ft86club.com/forums/showthread.php?t=148525)
C R 01-21-2022 05:50 PM
11 Attachment(s)
*for auto-dimming mirror*
I did the mirror tap for my radar detector today and it was fairly easy. Here's some tips for anyone wants to do the same:
step 1: remove plastic cover hiding the cables
step 2: disconnect electrical plug
step 3: remove T20 torx screw holding mirror in bracket
step 4: slide mirror up from the mirror mount to detach
step 5: identify red and brown cables on the mirror side of the plug
step 6: connect your mirror tap wires red to red, black to brown (I taped one of the metal connectors because they were too close to each other)
step 7: reconnect the mirror plug and test your radar detector.
step 8: route the wires in a way that once you install the mirror, the plastic cover fits over the cables
Here I opted to route the mirror tap wire through the opening in the middle and along where the mirror slides into its mount, otherwise the cables would be bent at too much of an angle.
step 9: reinstall mirror, it will still operate your garage opener if pre-configured
Optional: get a radar detector mirror mount for a clean install
There is a clip that attaches to the mirror stem to hide the wire, but I opted to keep it out so my mirror mount would fit.
These are the parts I used:
Mirror plug wires - https://www.amazon.com/dp/B097MGX318
Radar detector mount (find the one for your radar) - https://www.amazon.com/dp/B0063N7OZ2
dragoontwo 01-21-2022 05:54 PM
I found the brown wire to be the ground wire. Where did you get the info to use the yellow wire?
C R 01-21-2022 05:58 PM
Fixed it. The yellow wire seems to be for the mirror dimmer since the radar would shut off when using reverse. :lol:
Midnightsky 01-21-2022 09:57 PM
That must be with the upgraded mirror as an accessory, does it auto-dim too?
C R 01-22-2022 09:19 AM
Yes, it's the auto-dimming mirror. I'll update the post to reflect that too.
tenderization 02-19-2022 12:15 AM
Did you consider tapping the top plug rather than the mirror side? I think there's an install thread somewhere doing that instead so that the mirror doesn't need to be removed for the install.
