Rev counter Trigger
Busy with an engine swap in an 2013 GT86/FRS/BRZ, is all that is needed to get the rev counter to work with standard ECU to connect up the standard sensor on a original style trigger plate? No cam sensors, etc needed?
Have currently a 36-2 trigger plate being used for the engine, so will need to add an additional one fitted or get a electronically made signal from the 36-2. |
2013 uses a vr sensor, 2 wire as far as the plate it may need the same teeth lay out as the fa20 but it may work with your plate.
| All times are GMT -4. The time now is 12:26 AM. |
User Alert System provided by
