RS Motors in MN has done a couple. ASM in WI - I know he has one in his daily. |
You may want to check out RS Motors on FB..... posted some teasers today
Edit: RS Motors did confirm the new cam reluctor wheels are only needed for 13-16’ cars. |
Edit: RS is pretty responsive. I didn’t ask them for any more info since they did the work but it does appear with the FA24 short block they are using everything else from the FA20. I’d probably be best to ask them which route would be best to go with. I’d imagine for a DIY’er the complete engine would be easiest. The kit to do the complete engine is 700 bucks and they have 1st batch parts coming out. |
From the pictures on their FB for the FA24 shortblock swap it appears that the timing cover, upper oil pan & oil pan are used from the FA20 engine. They show a couple of pics of the FA24 block, no idea what, if anything is done with the heads to account for the 8.0mm bore difference (94.0mm to 86.0mm)...or if that is really an issue at all....
Looks like it will be at a simialr price point as the HKS FA20 2.1L Stroker kit Still very, very interested.... |
I do believe that they have FA24 complete swaps completed so that cars can complete in ClubTR for Gridlife, in addition to FA24 short block with FA20 heads/etc.
My question would be, would either generation of Harrop bolt properly into place with this FA24 block / FA20 head combination?
Does anyone have a picture of the actual cylinder heads from an FA24 from a BRZ/GR86?
I ask because I have an idea that has been brewing in my head.... FA24 block and cylinder heads with FA20 cam carriers, cams, front timing cover and oil pan (upper & lower). IF, and I say IF, this all goes together this would be a drop in FA20 replacement. It obviously would need a tune to make it happy but based on parts diagrams only it looks feasible. I have the ability to try and assemble this...looks like about $5k in parts (FA24 short block + L & R FA24 cylinder heads. I have a donor FA20 to get the cams, carriers, front timing cover and oil pans from. Anybody want to donate $ towards the parts, or donate an FA24, to see if this works? I'll put up $2500 of my own money.... |
Might be interesting as a proof of concept.
Using a non-OEM tune going forward as a marketing leader may be difficult. It could fly in Florida. Will be hard to pass a smog test elsewhere. Track only transported would likely work for the time being. Does using 20 cams offer some sort of advantage over the 24's? |
But there's only space for four.
@Kevin Vo tore down his GR86 you can ping him, I've seen a few more FA24D engine tear downs. Maybe you guys do a collab for YouTube, he needs content
https://www.youtube.com/watch?v=_obot4zuOyM Quote:
| All times are GMT -4. The time now is 09:32 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
