-   Engine Swaps (https://www.ft86club.com/forums/forumdisplay.php?f=92)
-   -   Likely the first FA2/4 hybrid incoming (https://www.ft86club.com/forums/showthread.php?t=147462)
Goingnowherefast 11-06-2021 11:18 AM
The question here is will it use the same CPS (crank position sensor). That's another critical sensor you'll need to determine engine position. If it is different, it may be possible to swap the gen 1 sensor in.
Ashikabi 11-06-2021 11:35 AM
Originally Posted by Brz-123 (Post 3479225)
It has the same casting and same stroke , no change. Only bored wider.
Sent from my SM-G781B using Tapatalk
Shouldn't the FA20 headers fit then?
Brz-123 11-06-2021 11:47 AM
Yes they should. Its also stated in one of the posts above. Change to intake side slightly , not to exhaust. I think even Mike at CSG is saying that in his new brz thread
Goingnowherefast 11-06-2021 12:33 PM
OP is using the FA20 cylinder heads anyways, so FA20 headers will almost guaranteed work. Will they be optimized? Probably not.
Brz-123 11-06-2021 12:56 PM
It is an experiment for sure but not a random one as the OP has put the gaskets on top of each other and verified oiling lines etc. How optimised or not with a minor change, the results of this will tell. We are all keenly watching as this is the first!
soundman98 11-07-2021 11:17 AM
https://i.kym-cdn.com/entries/icons/...on_be_good.gif
Opie 11-07-2021 01:48 PM
Per the documentation, it's in the same location.
EAGLE5 11-07-2021 03:03 PM
Redline is 6000k. Normally turbocharged. Designed for torque. Lower compression. It's interesting, but is it really going to have more power if not turboed?
NoHaveMSG 11-07-2021 03:15 PM
This is the 22’ BRZ short block he bought. Not the turbo Acent/Crosstrek engine.
Lantanafrs2 11-07-2021 04:21 PM
The fa20 heads seemed to flow more than needed so maybe they'll be dead nuts for the larger displacement?
Tatsu333 11-07-2021 05:32 PM
Excited to see how this build goes!
Is the plan to machine the heads to match the larger bore, or...?
Goingnowherefast 11-07-2021 05:41 PM
I'll let OP comment but that's usually not needed. No one does it on the really popular K20/K24 hybrid. It's a good example, because it's 2.0L heads with a overbored 2.4L crankcase.
Tatsu333 11-07-2021 06:44 PM
This is not *quite* the same as K20 / K24, since the difference in bore between those two motors is only 1 mm (most of the displacement difference there is with a jump from 86mm stroke to 99mm), while the difference between the FA20 and FA24 bore is 8 mm (from 86mm to 94mm) while the stroke stays the same.
That would mean a substantial amount of extra material sitting around the top of the bore, which at the very least would be sub-optimal for combustion, if not downright problematic.
This is closer in concept to an EJ20 / EJ25 combo - I haven't really looked into what they do with those, but I'd be surprised if the heads are untouched with a 7.5mm increase in bore.
EDIT: I looked into the EJ20 / EJ25 combo, and to do it properly, it seems they either machine the heads to enlarge the combustion chambers or use custom pistons to bring the compression ratio back down. Otherwise C/R is too high. That said, some folks DO run it without either...
EDIT 2: Running some quick rough numbers, the combustion chamber volume for an FA24 is 19.47% larger than the FA20's, so with the FA20's combustion chamber volume unmodified that would make the hybrid's C/R about 13.74:1. That is a BIG jump that would be hard to tune for.
The stepped shape at the top of the bore would also make for some funky swirl of the mixture as it compresses, and could create some major heat risers that would trigger detonation. With all that considered, I don't think it would be a great idea to run it without machining the heads to match...
Irace86.2.0 11-07-2021 07:34 PM
Machining the head seems necessary. The pistons could cause interference with the lip of the head, and if the lip of the heads are sharp then they could be a location for preignition, or at best, they could cause weird tumbling of air coming into the cylinder. Personally, I feel like getting the heads machined was already a given.
Tatsu333 11-07-2021 08:07 PM
That's kind of what I was thinking, but it seems some folks have done the EJ20 heads on EJ25 block combo without it.:iono:
Irace86.2.0 11-07-2021 09:49 PM
2 Attachment(s)
Originally Posted by Tatsu333 (Post 3479487)
That's kind of whatI was thinking, but it seems some folks have done the EJ20 heads on EJ25 block combo without it.:iono:
The EJ is a low compression motor. What do the pistons look like? They are recessed.
https://dsportmag.com/wp-content/upl...j257-06-up.jpg
The FA20/24D has domed pistons to create the high compression. Here are some pictures of my blown engine. The piston height is visible from the side, and the piston in the background shows a piston close to TDC with a dome shape and impedance reliefs in the crown for valves. I’m sure if someone wants to throw some low compression pistons in there then there is no risk of any issues. If Toyobaru changed the valve angle or valve opening height to make it open higher or enlarged the valves then that could cause interference, depending on the tolerances. Regardless, the edge of the cylinder-head combustion-chamber probably will interfere with the crown of the piston without machining.
Irace86.2.0 11-07-2021 10:00 PM
More pics
https://lh3.googleusercontent.com/pr...Ln3FY86TYjgb3w
https://uploads.tapatalk-cdn.com/201...3257eb59fd.jpg
PulsarBeeerz 11-07-2021 10:04 PM
I don't think that is true. The FA24D wouldn't include its larger intakes ports if that was the case.
Irace86.2.0 11-07-2021 11:14 PM
In general, they definitely don’t flow more than needed. There could always be more flow.
The intake manifold is said to flow well enough that it isn’t the bottleneck for NA power, nor is the throttle body, but the heads could definitely use improvement in flow by a port and polish, and they could use larger valves for sure. Doesn’t the FA24 head have larger valves? I know the intake ports and intake manifold is larger.
Will it fit?
https://motor--fan-jp.translate.goog...&_x_tr_pto=nui
Lantanafrs2 11-08-2021 04:12 AM
Then why doesn't port work show any gains on a fa20 (na)?
Tatsu333 11-08-2021 12:01 PM
Apparently, the FA20 port size and design is pretty good from the factory, so there's not much room for improvement / gains through porting with the stock valve size, but going to bigger intake and exhaust valves sees substantial gains in power, according to Element Tuning.
From their site (https://elementtuning.com/competitio...r-wrx-fa20dit/):
The factory heads are pretty good from Subaru but the valve size holds it back. When too much power is not enough look no further than adding our competition “Big Valve” head modification to your engine. Through years of testing on the track and on the dyno the key to maximum power is unlocking the potential within the Subaru heads. Element Tuning has discovered that the majority of the gains from the Subaru head are attributed to the valve size itself and not the intake and exhaust ports. Often “Big Valve” heads can be $4000 plus dollars due to the labor required to port the heads. The first step is to fit +1mm Ferrea stainless steel intake valves. The modifications to your supplied head (complete heads are available also at a higher price) start with a 3 angle intake valve job and it finished off with a bowl blend to maximize the flow through the intake port to the larger valve. On the exhaust side we also install a +1mm inconel valve and hone the guide but a 2 angle with radius valve job is performed. The exhaust port is again blended to maximize the potential of the larger exhaust valve.
Also:
Many may ask why don’t you port the intake ports fully? We don’t do this because almost 100% of the gain is realized by just fitting the larger intake valve and performing a bowl blend. (HP/value/compared to porting) On top of this the head retains 100% of it’s reliability due to how thin the cast walls are. It’s all too common to see highly stressed, high HP, road race engines blow through over ported head walls. The FA motors have nice and very large ports from the factory but extremely thin castings! With the big valve heads fitted to the motor we dynoed more than 60 whp gain at the same boost level with a 60 trim Garrett turbocharger.
That said, HP gains boosted do not necessarily mean similar gains NA since flow velocity can be much more important when you don't have a turbo / supercharger cramming in tons of air! You may gain peak power at the expense of the low-mid range with "too much" flow.
The pics posted of the FA20 vs. FA24 pistons definitely suggest larger valves on the latter judging by the size of the valve reliefs cut into the tops of the pistons...
Opie 11-08-2021 12:13 PM
The cylinder head / piston matching, clearance is definitely a concern that will be addressed once all parts are in hand. There are several options, each with pros & cons;
Use FA20 head "as-is": Pros - cheap, Cons - compression ratio, flow, combustion issues, etc.
Use "machine matched" FA20 head: Pros - better compression ratio, flow, combustion, Cons cost, proper design.
Use FA24 heads: Pros: will be a perfect match, Cons: Much increased cost, compatibility with Gen 1 intake manifold & components questions.
NoHaveMSG 11-08-2021 12:53 PM
Former forum member 86IT called Element about doing a BVH NA build and they told him it wasn't worth it. I'd dig up the post if I had time but I remember him talking about it. I could probably ask him on FB and see if he remembers what they exactly told him.
Irace86.2.0 11-08-2021 02:31 PM
Why do you say that? Wouldn't you have to see a port and polish as the only modification for the dyno session with a before and after, and then you would need to start adding modifications to the car in combinations, with and without the port job to see if there was a synergistic effect? Have you seen this data?
There clearly are gains in cfm to be seen by doing a port job. Assuming that doing so hasn't messed with some optimization in the system, then there should be gains. Maybe there would be other bottlenecks in the system like valve size or lift/duration from cams or raising the rpms where porting would be seen on the dyno. Maybe a header would be needed to take advantage or something else, but my point was that the heads aren't perfect, and they will be a bottleneck before some other components.
https://www.ft86club.com/forums/show....php?p=1630770
Tatsu333 11-08-2021 03:42 PM
I could totally see that being the case on the 2.0L since it would likely compromise the low-mid range for small gains up top, but it *might* be worth it if using the FA20 heads on a 2.4L block, particularly if the FA24's heads use bigger valves from the factory (I did a quick search and haven't been able to find any concrete info on the valve sizes for the FA24).
Presumably, using the smaller-valve head on the 2.4L block would give more low-mid range punch at the expense of a little less top end.
Would the difference be worth the $2K+ US it would cost to have the big valve heads done vs. the gains from other stuff (headers, etc.) for the money? Probably not.
If you're going to be in there anyway to clearance the heads, etc. for the bigger bore, though, maybe it would be worth paying the difference.
It's a shame you can't just use the FA24 heads, but according to the OP's information, it's not possible without at least using the FA24's intake manifold plus a LOT of other small changes (due to the various bits and pieces that connect to things on the heads) that would be a major pain and quite costly.
Kudos to the OP for taking on this project! A pioneering effort that will no doubt teach the community some valuable info.
NoHaveMSG 11-08-2021 03:46 PM
It could have likely been the gain wasn't worth the price of admission. I haven't had a chance to reach out to him today.
Tatsu333 11-08-2021 04:02 PM
I guess one other thing to consider is the positioning of the valve reliefs on the FA24 pistons vs. the FA20 head's valves. It doesn't look like they will line up when you look at the side-by-side shots of the two pistons, so there may be a clearance issue there as well.
As crappy (and costly) as it may be, there may be little option other than either using the FA24 heads (and all the added complexity that brings), or having custom pistons made with the FA20's shape in the middle 86mm plus an extra 4mm radius around the edge (if you can find someone to do that).
I guess another option might be spacers between the heads and block for clearance valve to piston clearance, but then you'll lose some compression.
EDIT: One other thought: what about some kind of machined adapter plates to use the FA20 intake manifold on the FA24 heads, like the Crawford Billet Power Blocks or a phenolic thermal spacer, but adapting the one shape to the other? Of course, there's still all the other stuff connected to the heads to deal with, but that piece at least could be not too crazy difficult.
It's awesome that you're taking this challenge on, man - best of luck!
Irace86.2.0 11-08-2021 04:56 PM
Probably would need to do a static interference test, and then do a valve interference test, and then maybe limit timing if there is no static interference and just some valve interference or grind down the piston surface at the expense of compression. Depending on the interference, a thicker or doubling up on head gaskets might create clearance, but again, this is at the expense of compression, and it isn't ideal.
Opie 11-09-2021 10:23 AM
Per the tech docs, FA24 heads use the same size exhaust valves (diameter & length), intake valves are the same diameter, but the length it a few mm longer. I assume to open a little more and allow slightly more air into the cylinder.
Opie 11-09-2021 10:27 AM
Lots of measuring and testing to be done before assembly...as I said, using the FA24 heads may end up being the answer...but I'm sure going to see if the FA20 heads are a possibility first.
Short block did not arrive as expected yesterday...still waiting
dragoontwo 11-09-2021 10:41 AM
Opie, thanks for doing the needful. It will be interesting to see what comes of this.
NoHaveMSG 11-09-2021 01:11 PM
I'd still call using the FA24 heads a possible win when you consider what a K swap costs. If it all still works that is, which I believe it will. I would be over the moon happy if this thing does at least 220whp with bolt ons. I am not looking for big power.
Irace86.2.0 11-09-2021 01:42 PM
Are you familiar with interference testing? I’ve never done it, but the K crowd does for cams and high compression builds. Apparently you have to apply puddy to the piston head and then torque down the head and then remove and analyze, and then repeat. It is fairly laborious.
Lantanafrs2 11-09-2021 02:16 PM
Or allow a taller port
Lantanafrs2 11-09-2021 02:18 PM
More commonly known as clay checking. I've done it and its time consuming but necessary when using different cams, pistons, valve sizes etc.
Irace86.2.0 11-09-2021 03:41 PM
Unless something has been vetted already.
Tatsu333 11-09-2021 04:53 PM
That's overall good news for performance with the FA20 heads then!
If you *did* end up going with the FA24 long block option, once you figure out everything that's necessary, you could maybe put together and sell a kit for adapting everything to the FA20 intake manifold and ancillaries.
Based on the interest in this thread, I'm sure there'd be at least a few takers... ;)
Brz-123 11-09-2021 05:08 PM
Yes, please think about doing that. A package / kit
Opie 11-09-2021 05:31 PM
Never done it, but have heard of it. Also will be using a borescope to see what happens....
Opie 11-09-2021 05:34 PM
In other parts of the world....Subaru sells long block assemblies that would make this a much easier decision...but in the US you can buy all the parts and build an engine, or buy a complete engine assembly including exhaust manifold, intake manifold & accessories....not a long block.
