Everyone makes so much of this noise thing - its very meh for me but I sure as hell won't be focusing on it when I'm driving!
Can't wait. Can't wait. Can't wait. Must wait. |
I’m surprised people like the sound of a stock 1st gen. I personally thought it sounded grating and made the engine feel less willing to rev.
Love the sound on my 2013 now after a few easy mods (sound tube delete, 2017 oem header, trans mount bushing). Much smoother overall. Makes me want to redline it just to hear the engine rev out. The gr86 engine sounds a bit artificial but I’d have to hear it in person. I can already tell I like the sound better than a stock first gen though. |
These two engine are very different, at least based on my seat time in a 2017. My 2013 engine sounds like gravel in a blender. The catback helps to drown it out, though. Based on the various videos we have, including one with the augmented sound turned off, I would agree that a 2017+ engine has a more interesting mechanical noise. The 2022, with both the augmented sound turned off and on, was a lot smoother and sounded more pedestrian. Like it belonged in the Outback or Legacy. But I will have to hear it in person, obviously. |
1. chassis could be quieter - hence the need 2. lighter weight to have a small speaker than an entire sound tube system (which also previously had many of its components on top of the engine/high side in the engine bay) 3. cheaper to produce one speaker, mount, and assumably an onspeaker amp than producing all the tubing/mounting/clamps for the sound tube system: http://i.imgur.com/wyiTNJL.jpg |
Sound tube system weighted 1lb 8.5oz. Not sure how much the new speaker(-s) system weights, but it looks to me more complex and requires additional battery consumption.
Source: Powertrain NVH Engineer :) |
Source: Service manual ETA Other source: https://parts.subaru.com/a/Subaru_20...11-862-02.html Part number 86301AB. It is not currently active in the parts database, but that is the dedicated engine noise speaker. |
We looked. It’s a separate module driving a separate speaker box. It’s fed by fuse 28 and hooks into the body control module, presumably to get engine load/rpm over the bus. |
2020: https://parts.subaru.com/images/part...0_86201091.png 2022: https://parts.subaru.com/images/part...1_86201166.png also check your PMs |
@ mentioned this would work, so maybe he can clarify. I guess we won’t know for sure until someone tries it and documents. |
They should’ve simply skipped this feature, it’s cost and complexity for something silly. |
Just give people a no-cost STI muffler option. Problem solved. |
Most car companies now run the technology in some way, even the porches and BMWs etc. As we all know, modern car engines have become more and more muted by efficiency to the point where its difficult (unless you are open top) to hear a lot, NVH has also gotten a lot better, which in turn dulls down things further. Turn this car into a track machine and remove all that NVH and/or pull out those restrictive cats and sure, it will sound no different to any car built in the last 30 years with 4 big fat cylinders running to 7500k - bloody good! |
NA first drive days for GR86 first week of August
That’s not my point though, Toyota did very little engineering and development on this car. It’s not like the first Gen, Subaru already has the Toyota tech like D4S integrated into the car, Toyota was way more hands off until Akio told them to make it ‘different’ very late into development. They probably just rubber stamped Subarus drawings for the active sound control. Integrating their own solution into the Subaru electrics wills be way more effort and not worth it. Quote:
I mean it’s likely a canbus line so it should be flexible. These cars don’t use a fiber optic system like MOST do they? |
| All times are GMT -4. The time now is 05:11 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
