-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   Knockoff coil packs (https://www.ft86club.com/forums/showthread.php?t=145414)
DarkSunrise 10-16-2021 02:05 AM
Originally Posted by jflogerzi (Post 3473566)
I don't see them on the site. I have killed my second coil same one cylinder 1. How have they held up? Thinking of just getting OEM one and wrap some gold tape to help keep some heat out
Sent from my Pixel 5a using Tapatalk
In my testing, the gold foil didn't do anything. It might have actually shortened the life of the coil (only lasted 2,022 miles with the foil).
jflogerzi 10-16-2021 02:43 AM
Cancelling the order
thekevinvo 10-18-2021 03:05 PM
Not sure if I can post the link since I'm affiliated, but if you just search SSFA2X-4 on FTspeed you'll find them.
Four_wheel_drifts 10-22-2021 03:30 PM
Gold tape should always be used regardless of OEM or aftermarket coil.
Looking at the icefabrication.com site, why wouldn't one just buy the 2015+ connectors at $12 each and repin our 2013 ones?
Seems much cleaner and easier than cutting and splicing using their $90 kit.
I'm very wiring competent and can do either. Just wondering if there are hidden gotchas I'm not seeing.
Shneegle 11-17-2021 12:07 AM
Originally Posted by redlined600 (Post 3471957)
These were the blue benchmark coils mentioned above?
That is correct the ebay blue benchmark coil failed. Swapped it with one of the two good OEM coils I had and my CEL hasn't come back. Before I was getting it every session.
EndlessAzure 11-22-2021 03:20 AM
OTL now sells an OEM rev1 to rev2 connector adapter. Planning on buying those to go along with a set of used rev2 coil packs for $100 on ebay.
@jflogerzi
jflogerzi 11-22-2021 01:39 PM
@jflogerzi
any re-pinning needed?
EndlessAzure 11-22-2021 03:26 PM
Not that I saw.
https://youtu.be/U9aY5ddhi5M
sato 11-26-2021 05:03 PM
@jflogerzi
https://www.ftspeed.com/part/coil-ad...t#.YaFDDdDMKUk
Can't find it elsewhere, not even directly from OTL.
