-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   Mechanical overrev, 9k (https://www.ft86club.com/forums/showthread.php?t=145262)
CSG Mike 05-11-2021 02:59 PM
Originally Posted by ZDan (Post 3431428)
The issue also correlates with not starting session with a full tank. But yeah, the 1st time it happened was only a few laps after the overrev. Engine sounded extremely valve-noisy to me but then I listened to my bud's same-year 86 and it makes the same noises (mostly injector noises I think). We have similar setups, and our acceleration plots fell right on top of each other so my engine is performing normally otherwise.
Still, I was thinking that maybe VVT mechanism(s) might have been damaged and might quit "VVTing" after a few laps, but why would it reliably fail at exactly the same spot on the track every time? @CSG Mike's post about starvation "under the right conditions" is hugely encouraging. Heavily banked 180-degree left-hand NHMS Turn 6, with a little flat table top I use at track-out, while continuing left into Turn 7, on tires that honestly feel faster and more confidence-inspiring here than even 8-cycle Hoosiers I was on last fall, might all add up to "the right conditions".
Bingo.
Fuel pickup is on the driver side.
gen3v8 05-11-2021 06:42 PM
I also get the the loss of power ,with exhaust backfiring, after a double left hander that links(Fish Hook). 6k rpm in 3rd on semis with less than a 1/2 tank or 3/4+ RHD. Must be fuel as I have not revved past 7.6k and it only happens when you nail the section.
54fighting 05-12-2021 06:42 AM
Can someone school me, isn't our rev limiter set well below 9k?
gen3v8 05-12-2021 07:13 AM
One Scenario.. 4th gear 7.5k rpm and shift into 5th, but you hit 3rd gear by accident. Mechanical over rev! 9k rpm give or take
Dzmitry 05-12-2021 11:14 AM
Not an issue with auto, but with a manual, you have full control over the gears and revs. An extreme example, but the ECU can't stop you from shifting into 1st gear going 60 mph. The rev limiter is only controlled under acceleration, not through gear changes, as this is purely mechanical.
RKTSGN 07-22-2021 06:58 PM
Originally Posted by jflogerzi (Post 3431309)
ecutek would should show these as well which he has access too.
Would this be able to check our ECU for evidence of an overrev event? And if so, how can we find it? Thanks.
jflogerzi 07-22-2021 07:42 PM
Only if it created a code but not over rev
Hades 07-29-2021 07:24 PM
Speaking of fuel starvation - whats the fix here? Aftermarket fuel pump?
CSG Mike 07-29-2021 08:13 PM
Race car? Surge tank.
Hades 07-30-2021 07:42 PM
No not race car, more dual purpose track/street car. I guess there's not really a solution for that scenario?
CSG Mike 07-30-2021 08:50 PM
Just run a full tank.
Hades 07-31-2021 12:50 AM
Is this adequate with F/I + R-comps though? Sounds like F/I for a street car basically means no racing slicks/high Gs otherwise.
EDIT: Sorry to hijack thread lol
CSG Mike 07-31-2021 01:29 AM
Depends on the rest of the car and what exactly you want to do, but probably yes.
