Reducing negative camber with control arms after lowering
Hello everyone,
I've lowered my car 1.25" on tein s tech lowering springs, in order to reduce negative camber I've installed ultrapower control arms. They are basically SPC control arms and look like this https://images.app.goo.gl/gWiX4Eg4spQTSWas9. The issue when I have the adjustment bolt set for the least amount of negative camber I'm still at at -2.8 degrees. I have double checked the eccentric bolt and it is in fact set to the most inboard position. Any help would be appreciated. Thanks. Sent from my SM-G991W using Tapatalk |
you may have to invest in some proper adjustable control arms with more range.
Something does not sound right.
I am lowered quite a bit more than 1.25" and also running SPC rear lower control arms, but I can adjust for a lot less negative camber. I am running at -2.3 now, but I had -1.9 on the previous alignment. So you should definitely be able to get in that range with only a 1.25" drop. |
Odd, I'm also at -2.8 degrees with factory control arms, also lowered 1.25".
IMO that's a liveable amount even for a street-only car if you rotate tires at least once in their life. And if you're going to track or autoX, it's about where you'd want to be anyway. |
Unless you're super-worried about tire wear, I wouldn't worry about it. And even on that point, reducing only rear camber to, say, -2 degrees, you'll probably only get about 5-10% more overall tire life, particularly if you're running minimal toe-in. |
How did you determine you still have that much camber after adjustment? Was that confirmed at an alignment shop?
If you have the stock toe arms you will be limited on how much camber you can pull out. I was able to take 0.5° out of the rear evenly before maxing the toe arms. Lowered on RCE yellows 0.8"/20mm drop. Any more taken out the rear wheels toe out on the rack. A set of SPC toe arms would solve that. |
OP, I'll bet you're turning the eccentric the wrong way, I'm about 1.25" lower on stock LCA's and only have about -2.2* in the rear. |
I think it’s also a matter of how stiff your suspension is, with soft springs probably less static camber is better while more camber is needed with a stiffer setup. Anyway as ZDan said rear camber isn’t critical, even if it’s a bit more than ideal, front camber is much more important and it’s not a secret that these cars need up to 3.5 or even 4 degrees of negative front camber to perform well with a decent tyre wear.
That's true for the rear, but the fronts gain no camber (and actually lose some at peak compression) through compression. |
Compared to rears fronts gain a bit dynamic camber when turned from caster though, even if they don't gain from compression. Then again, no that much at small turn angles, which is more common in smoother track driving.
| All times are GMT -4. The time now is 09:45 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
