-   BRZ Second-Gen (2022+) -- General Topics (https://www.ft86club.com/forums/forumdisplay.php?f=98)
-   -   All-New 2022 Subaru BRZ Makes Global Debut (https://www.ft86club.com/forums/showthread.php?t=143209)
jflogerzi 03-29-2021 11:54 PM
They increased redline and the tq comes on sooner. As long as power holds to redline should be just as fun. Hopefully the 2.4L will sound better
Blighty 03-30-2021 08:27 AM
Originally Posted by anticubus (Post 3417946)
That's what I'm saying with the 2ZZ comparison. It was as much a clean sheet engine compared to the 3S series as the FA is to the old EJ blocks. Toyota is still using D4-S in their newer engines, things were much more NA performance aligned for the first gen. The newer FA24 is going to move the car faster like the 10th Gen XRS (That did exist, powered by the camry's 2.4L engine. https://www.motorweek.org/reviews/ro...ta_corolla_xrs) in that it's getting more power from displacement and I don't suspect much else. It also isn't as likely to enjoy revving out just because it's a bigger engine.
This is 100% speculation though. When they're out I'll test one and we can all laugh at my terrible predictions if it's way more fun and I end up trading mine in or something like that. I don't think that's happening though, the styling also isn't very appealing to me vs the current gen.
The 10th Gen XRS was using a completely different engine tuned for a regular passenger car, and made way less power than the 2ZZ - it was not faster.
It had more torque of course, but torque like an agricultural vehicle, not a sports car.
Yoshoobaroo 03-30-2021 09:32 AM
From quickly looking up the 2 on reviews, the 10th gen was about a second slower to 60 than the 9th gen. No wonder it feels slower. The 2.4 has more torque down low but when you're wringing it out that doesn't matter if you still make the same power up top, and weigh 300lbs more. I'm sure it feels quicker around town accelerating in the lower rev range, but that's probably it.
Sasquachulator 03-30-2021 10:40 AM
The camry motor is just a lazy non-performance oriented motor.
It made power, it made sounds...it was...an engine.
The 2ZZ on the otherhand....sounded like a motorbike at high revs and wailed like a banshee when it engaged lift...and Lift gave it a turbo-like kick in the butt. VETAK KICKED IN YO!!!!
anticubus 03-30-2021 06:13 PM
This is exactly what I'm referencing. It doesn't look like the FA24 is going to enjoy being up towards the 7K range, but it definitely resolved the torque issues. I like revving it out so the torque dip wasn't a huge issue in daily driving but after focusing on my cornering there are lots of times where it becomes a choice between landing in the the dip or a shift mid-corner.
I wasn't making a direct comparison to the 2.4L out of the 10G XRS, just noting that the two BRZ generations have followed a similar engine pattern. The FA20 and the FA20DIT landing in the BRZ and then quickly the WRX means they saw more performance oriented design aspects like the high redline and in Toyota's case the focus on extracting all the NA performance regulations and engineering margin would allow them. Then the next generation we get an NA version of a turbo SUV engine with a more hands-off approach from Toyota. I'm worried it's going to drive like one. With the announcement their model is getting pushed back I'm definitely not buying first year.
ZDan 03-30-2021 08:55 PM
It makes peak power at 7000rpm. That is where it wants to be. And it makes 23hp more than the current gen at that rpm. We get another 100rpm before the rev limiter, so it will stay (slightly) further up in the powerband after upshifting. I don't see any downsides. Here's what relative rear wheel hp and torque should look like:
Yoshoobaroo 03-30-2021 09:22 PM
This shows perfectly that the motor should be similarly rev-happy as the FA20
Another good indicator is that the stroke (86mm) was unchanged, and only the bore enlarged (86mm>92mm). Typically engines with larger bore/stroke ratios like revving more than ones with lower bore/stroke ratios.
ermax 03-30-2021 10:41 PM
Especially when that extra space is used for larger valves. Most of the time when getting a displacement bump OEMs go with a longer stroke which negatively impacts high revs. Fortunately they didn’t go that route. There’s no reason this new engine should be less rev happy.
nikitopo 03-31-2021 01:53 AM
The only issue I can see with this engine is the higher compression ratio (13.5 vs. 12.5), which it could affect performance more with lower quality fuel. Such compression ratios were used in the past mainly in racing applications, where someone had access to racing quality fuel. It looks they went into that direction to extract the best possible performance figures under this displacement level and latest emission regulations. E85 and Flex fuel kits could be a solution for those having access to such type of fuel. And of course the worst option would be to supercharge such a high compression engine ...
Yoshoobaroo 03-31-2021 07:36 AM
I bet it's still fine running on 87AKI. It may be optimized for 91/93 but I kinda doubt that being that the US public has such an aversion to using higher octane fuel for some reason. We'll see I guess. I'm excited about the C/R bump, I always run 93 in my cars anyway since they all have at least a 93 Octane tune on them anyway.
Tcoat 03-31-2021 08:14 AM
The current engines, at the lower compression ratio, recommend 93 and require 91 so there is no way that they are going to increase the compression ratio and reduce the octane requirement.
Cephas 03-31-2021 09:02 AM
I doubt they'd lower the recommended octane, but that doesn't mean the car won't run sorta okay on lower grade fuel. The ECU is smart enough to pull enough timing to make it work.
Tcoat 03-31-2021 09:48 AM
The current engine runs sorta OK on 87. The new one is a substantial increase and would probably be pushing even the ECU to it's limits as far as correction goes. In other words it would probably run like crap. Even Joe and Jill Generalpublic would notice the difference.
ZDan 03-31-2021 10:13 AM
They likely have the same basic requirements regarding how well it runs on 87 for the new model as for the current one. Could be improvements to combustion chamber design, fueling, and spark control make it possible to have the same "driveability" with lower octane fuel with the increased compression ratio.
long/short: I wouldn't worry about it... Especially since we're all gonna use 91 octane minimum anyway!
