Difference in TRD Exhaust Parts
Hi,
Does anyone know the difference between the two TRD exhaust parts that are listed on Toyota's site? PTR03-18170 https://www.trdusa.com/parts-detail....categories=all PTR03-18190 https://www.trdusa.com/parts-detail....categories=all Thanks, cityxr |
One fits 17+, the other fits Pre-17' models. The axleback to midpipe connection changed in 17'.
Edit: NVM they both list 17' compatibility. So :iono: |
Both should work. Both seem to be not axlebacks, but complete catbacks, no? In such case, if one is using midpipe & axleback from set, it's normal that both can be fitted.
Perhaps one is a outdated part # ?
Doesn't make any sense based on photo provided. 2019 TRD 86 has a Different exhaust tips over standard TRD system. No changes in fitment when catbacks are installed. |
It could be as simple as a changed bolt which makes no difference at all. The price difference probably just reflects the old vs new listing. |
Good points here. Thanks for taking a look!
The Bolts, I believe, are components of the Hardware Kit. So a change to any of those shouldn't change the part number of the Exhaust.
I honestly have no idea what the difference is. Unless one of them is the Exhaust that came with the Release Series 1.0, and the photo is just not accurate. |
I too was wondering the same thing. It looks like the cheaper one is for 2017+. Not sure if the link shows the difference, but it appears to be a bolt or some other connector that is different (shows up in green). WHY DOES THAT SMALL PART MAKE IT $200 LESS?!!!
Could I buy the cheaper exhaust and use the connectors from my stock exhaust? https://toyotaparts.bochtoyotasouth....-sr-ptr0318170 |
Why do you want TRD? They drone with anything but stock Headers and FP.
but...those....tips..... |
I'd guess one is just a new part number with an increased price. |
Part Number: PTR0318170
https://parts.toyota.com/p/Toyota__/...TR0318170.html This product fits 27 vehicle variants. Scion: 1 models, 8 variants between 2013 and 2016. Toyota: 1 models, 19 variants between 2017 and 2020. Scion FR-S 2.0L AT 2013 Scion FR-S 2.0L AT 2 Dr. Coupe 2014, 2015, 2016 Scion FR-S 2.0L MT 2013 Scion FR-S 2.0L MT 2 Dr. Coupe 2014, 2015, 2016 Toyota 86 2.0L AT 2 Dr. Coupe 2017 Toyota 86 2.0L AT 2 Dr. Coupe High 2018, 2019, 2020 Toyota 86 2.0L AT 2 Dr. Coupe Special Edition 2018, 2020 Toyota 86 2.0L AT STANDARD 2018, 2019, 2020 Toyota 86 2.0L MT 2 Dr. Coupe 2017 Toyota 86 2.0L MT 2 Dr. Coupe High 2018, 2019, 2020 Toyota 86 2.0L MT 2 Dr. Coupe Special Edition 2018, 2020 Toyota 86 2.0L MT STANDARD 2018, 2019, 2020 Toyota 86 2.0L MT TRD 2019 Part Number: PTR0318190 https://parts.toyota.com/p/Toyota__/...TR0318190.html This product fits 17 vehicle variants. Scion: 1 models, 12 variants between 2013 and 2016. Toyota: 1 models, 5 variants between 2017 and 2019. Scion FR-S 2.0L AT 2013 Scion FR-S 2.0L AT 2 Dr. Coupe 2014, 2015, 2016 Scion FR-S 2.0L AT 2 Dr. Coupe Release Series 2.0 2016 Scion FR-S 2.0L AT 2 Dr. Coupe SP Edition 2015 Scion FR-S 2.0L MT 2013 Scion FR-S 2.0L MT 2 Dr. Coupe 2014, 2015, 2016 Scion FR-S 2.0L MT 2 Dr. Coupe Release Series 2.0 2016 Scion FR-S 2.0L MT 2 Dr. Coupe SP Edition 2015 Toyota 86 2.0L AT 2 Dr. Coupe 2017 Toyota 86 2.0L AT 2 Dr. Coupe Special Edition 2017 Toyota 86 2.0L MT 2 Dr. Coupe 2017 Toyota 86 2.0L MT 2 Dr. Coupe Special Edition 2017 Toyota 86 2.0L MT TRD 2019 there you go. |
So much overlap between those two lists. Doesn't make much sense.
| All times are GMT -4. The time now is 02:39 AM. |
User Alert System provided by
