The 0-60 of 9.2 seconds kills it for me, even if everything else aligned. Maybe you should wait three years, and you could buy one for $5k or less. https://www.youtube.com/watch?v=j9fQ-eugcpw |
I drive upwards of 40-50k miles a year so my hard expiration date is more like whatever amount of driving the fuel card can get me. |
Have they started selling in the US, or announced when they will? Their nio.com website is relatively useless, containing mostly marketing blurbs and stock photos of beautiful people doing beautiful things. |
If Toyota is offering a $15k hydrogen gas card to gain early adopters then offering a battery swap option seems like an equally necessary investment to gain early adopters. In time, batteries will out number vehicles on the road. Tesla has already said that they plan to move much of their material harvesting to in-house battery recycling, but the industry is already buying used batteries for grid storage and home storage. Alternatively, gathering used batteries from old cars to wrecked cars can be done to use for swapping. People are already doing used battery swaps to upgrade their P75D to a P85D. Like selling a used iPhone back to Apple or a third party manufacture, maybe old cars might be sold back to battery reclaimers and vehicle refurbishers. Even if the range on the battery is only 70%, for many people, 175 miles from a once 250 mile battery is still plenty of range until their next swap. Obviously, 70% charge performance from something like a 500 mile battery (350 miles) is definitely enough. There could be a tier pricing system for the swap or a monthly prescription or whatever a company would need to do to incentivize buyers, while recuperating their initial expenses. |
https://www.reuters.com/article/us-g...-idUSKBN29X2AY
GM aims to end sale of gasoline, diesel-powered cars, SUVs, light trucks by 2035 |
Also hope GM continues to make "last hoorah" versions of their cars. For example, I'm convinced the upcoming limited Cadillac CT4/5 Blackwings (reservations start 2/1/2021) with manual transmissions will be the last opportunity to buy an ICE version of those type cars, and they will only sell 250 of each this year. If ICE is going out, I want it to go out with a bang, not a whimper! |
I just hope the upcoming vehicles don't all suck.
Quick framegrab |
There will probably be net zero biofuels. We have a long time. I’m almost 40, and I’ll likely be able to drive an ICE for the rest of my life, assuming a long life. |
China's vehicle market is going electric much faster than the rest of the world, and to not go EV is to lose out on the largest consumer market to other brands. |
Don't expect ZL1 or C8 ground clearance for a long time. https://cnet1.cbsistatic.com/img/wIh...-zl1-1le-1.jpg It will probaby be similar to the Mach-E, but a 2 door. https://smartcdn.prod.postmedia.digi...=100&strip=all |
The other thing is that these companies need a new focus. The horsepower wars are getting so ridiculous that there needs to be a new focus to reign in the power, or rather, where do you go from a 700+hp sports coupe? There are engineering limits on cooling, reliability, fuel economy, weight, etc with ICEs. Going EV could reset and restart the bar. At one point in time, Japanese cars had a gentlemen's agreement on 280hp or something, and now, we may see an agreement to move past the latest horsepower wars and move onto something different. https://www.wired.com/2015/05/porsch...orsepower-war/ |
It depends on the type and configuration of their battery packs. Some manufactures are using larger pouches, so their battery packs are taller, which can raise the seat height. Look at the Model 3 or Model S, and you can see that the vehicle doesn't need to look like a crossover because it has a battery pack, nor does the seating position need to be high in the air. The Mach-E has a crossover look because that is what they wanted to make because crossovers sell the most. |
Are they ramming CUVs or are we wanting CUVs? Is it a push or pull situation? That is the question. |
If I puncture my gas tank nothing happens except oil spills out over the road and eventually evaporates and we replace the gas tank. If I puncture a car's battery pack, at best there is no fire but the entire car would be totaled because you can't simply replace the battery pack, and at worst the entire car catches fire. |
Not a reason to drop all. The reason may be different, including regulations (e.g. CAFE), profits, cusromwr demand, shifting of CEOs, new direction... |
https://www.cnet.com/roadshow/news/2...nt-lift-video/ Fires are much more common with ICEs than EVs. The incidents typically don't happen from tank punctures, but that is possible. Typically it happens when a fuel line, injector, regulator, etc leaks or breaks, and the gas hits the exhaust pipe and starts a fire. This happens with oil leaks too of course. The GT350 had a recall because several cars caught on fire from the oil filter not sealing well enough. Then there are the physical damages from a crash or catastrophic engine failure that can cause a hole in the crank case or a leak, which can start a fire. You are correct that a serious impact to the bottom of the car will likely result in more expensive damage, but this is very rare. The battery area under an EV is also bigger than say the area under an ICE vehicle where an object could puncture the oil pan that could cause engine failure, so there is a greater chance of an impact with an EV. Yet, the under trays of EVs are very thick. Some EVs like Ford's Mach-E has individual sections that can be changed out if one got damaged. https://www.macheforum.com/site/atta...8405-jpg.1702/ On the newest Teslas, the batteries will be integrated into the floor like how some engines in motorbikes or race cars become integral components of the chassis, so removing the battery may not be as easy or possible. Initially they planned to design the car, so the batteries could be swapped, and while other companies like Nio are providing that service, Tesla is moving away from that model because it seems less necessary. But, previously, Teslas could have their battery packs removed and replaced, which was very common, and like a broken engine, they could be recycled and harvested for parts and materials. Most wrecked Teslas showed little to no major damage to the battery packs. Nio has performed over 500,000 battery swaps so far using these swapping stations: Tesla battery pack: https://057tech.com/pimages/packsolar.jpg Nio swapping station: https://www.youtube.com/watch?v=oTXptUuKGrc |
Speaking of Tesla, they were just forced to recall 135,000 vehicles because the center tablet may fail. Tesla refused to voluntarily recall them because they didn't think the failure was a safety issue, even though some systems, like the backup camera and the window defrost systems are controlled by it.
Of course, I may like him because he sounds like a Muppet. Only thing, I think he missed the point that it's not quite that straight forward. Charging at night also makes use of electricity production that is now "lost". That is why, for example, my EMC (electric co-op) let's you charge a car for free if you do it between certain hours (up to 400kWh per month). The video itself is a bit weird though. This would have been better done in the studio similar to his video on the CT5-V Blackwing. The driving and random shots of Hummer EVs, Mach-Es, etc were distracting.CT5-V Blackwing |
There are examples of this in the production of electricity, although not exactly the same thing. For example, in some cases of hydroelectric power, the generators required to provide electricity during the day to the grid may not be needed at night. Rather than turn the generators off, they are used for another purpose. For example, in Georgia, Lake Oconee is a power generating lake and Lake Sinclair (downstream) is basically "battery storage". Each night, the excess power generation is used to pump water from Lake Sinclair back into Lake Oconee, then that water is reused to power the turbines during peak times. Lake Sinclair, as result, has a low and high "tide" every day as the water is pumped out then flowed back in. |
On a separate note, the US is one of the most wasteful countries in how we use energy—in terms of absolute amounts and per capita, so we have the capacity to improve on that metric to get more energy by not wasting more energy. For example, many homes could be much more efficient. New homes are being designed with smart cooling/heating and zone climate control, better insulation, etc. |
Plants can run continuously but whether they generate power or not is a different story, depending on how they generate power. Wind is pretty much based on forecast and location, so it is variable. Hydroelectric usually are at dams, so they can turn it on/off as long as the dam is not at capacity. etc etc... Other plants like coal/oil/gas/nuclear usually are always "on", so the only variable is whether they are running at 25% or 100% based on demand. This real time graph shows the overall US electrical grid at any time with info on supply and demand. The only real concern is what the forecast electrical need is vs what is actually available, and whether or not excess capacity can be provided in case of spikes. https://www.eia.gov/realtime_grid/#/...nd=20210211T12 |
| All times are GMT -4. The time now is 11:28 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
